You can get the Adire Shiva here for $175 CAD SHIPPED.
All you'd need to do is stop by a local car stereo shop or, in the worst case, worstbuy/futurecrud and get a 1.5cf sealed box for ~$75.
In that box, the Shiva will handle your amps 460watts no problem.
For that money, you won't be able to beat the depth, accuracy and power handling of the sub. Only the Infinity Kappa Perfect 12 comes close... that futureshop sells for ~$400cad...
<edit>
Often times deeper is confused for "warmer" or "sloppier", whereas a bit of boominess (usually due to the box being too small) helps to give the impression of "punchiness", which is often confused with accuracy/sound quality.
The Shiva will simply sound deep while maintaing good sound quality at any amount of power your amp can put out. </edit>
<edit>
