I just built a new rig with a Intel Core i7-2600K Sandy Bridge 3.4GHz.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
I'm cooling it with the Xigmatech Dark Knight.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Mobo: Asus P8P67 Deluxe (B3)
The CPU seems to be running hot, idling at 47C. I'm going to try to re-seat the heat-sink (as it doesn't feel very warm), but I'm not sure that the temperature is being reported properly. After two hours of playing Crysis 2, the temperature only increased to 50C.
1.) What are the normal temps for Sandy Bridge CPUs?
2.) Does anyone suggest a better heatsink?
3.) What do people use these days to track historical temperature data from within the OS?
Thanks!
Thanks!
