richierich1212
If you use the + key on the keypad you'll see the speeds. Don't use enter 😉. HT link speed should stay at 2200MHz at the most, 2000MHz minimum.
Overclocking this high on stock cooling is a recipe for disaster. Come on.
choliscott,
I see that you're using stock cooling, what kind of temperature are you getting?
When I did the load test I was getting about 55-57c & on normal use between 40-45c
What are you using for temp monitoring? That unlocked multiplier has to make the OC process a lot easier
-Wes
