Originally posted by: tuteja1986
Cat6 is nearly about the same price. So i suggest get Cat6.
Noob version:
Cat5e = 200Mbits
Cat6 = 1000Mbits
CAT5e is rated for 200Mbps and CAT6 is rated for gigabit Ethernet.
Technical
They use the same cable but the twist it more. the rest you can figure out by googling
Originally posted by: Unkno
anyone know why i shouldn't buy cat6 over cat5e before i buy it?
Noob version:
Cat5e = 200Mbits
Cat6 = 1000Mbits
Technical
Actually cat5e and cat6 don't use the same cable.
Cat6 uses a larger cable pair. 24 gauge vs 26 gauge I believe.
Well, i'm planning on getting a 100ft ethernet cable...
Does anyone know the difference between Cat6 and Cat5e? Are there any performance difference (in real world)? Is it worth the extra money?
Thanks in advance! Here's a![]()
