jlee
If time is money then why are you wrenching on your own car in the first place?![]()
My time isn't worth $95/hr yet. 🙁
Or hoping the guy doing it knows his stuff lolMy time isn't worth $95/hr yet. 🙁
Turning a rotor for $10 seems a pretty decent deal, but given the time required to:
1. Lift the car
2. Remove the wheel
3. Remove the caliper
4. Remove the rotor
5. Turn the rotor
6. Install the rotor
7. Install the caliper
8. Install the wheel
9. Lower the car
How does a repair place make money at $10 for this? OK, if they charge of new brake pads and tire rotation the total work might be reduced to items 3-7 that's still a good chunk of time -- I wouldn't do it for $10.
Frankly, given the relatively low cost for new rotors I'd prefer to pay to change it than have a low paid grunt worker do machining on my rotors. If they're only charging $10 how careful are they likely to be?
Brian
1. Lift the car
2. Remove the wheel
4. Remove the rotor
5. Turn the rotor
9. Lower the car
Brian
1. Lift the car
2. Remove the wheel
4. Remove the rotor
5. Turn the rotor
9. Lower the car
Brian
1. Lift the car
2. Remove the wheel
4. Remove the rotor
5. Turn the rotor
9. Lower the car
Brian
Are they still common? I always thought it was a better way but they seem to have fallen by the wayside with floating rotors being everywhere.This is a "carry-in" price. Also you probably don't know what a "one the car/wheel lathe" is. Most major brake shops can turn rotors on the car frame.
Check the thickness and turn them....
lot of German companies make them thick to get you to buy new rotors at every brake change...
This...
My last car was sold at 140K with the original factory rotors.
No pulsation. Technically still in spec (but I will admit they were borderline when I sold it). Not bad on a then 13 year old car with close to 140K)
My current car (a 2002 with 77K on it is also still on the original rotors.
Since I'm "inexperienced" at this constantly replacing \resurfacing rotors thing I always interested when others talk about it.
The F150 front rotors had to be turned on the vehicle a few years back, I'm not sure if that's still the case. I assume it was done to stop shade tree mechanics from replacing brakes.
I follow a few simple rules and I'm still running on my original 10yr old rotors, 1st off is ALWAYS check the torque on the lugs with a torque wrench, even if they say they do I don't trust tire places. 2nd is when you have to make a hard, sudden stop from high speed try (if possible) and get your foot of the brake pedal ASAP and slip it into neutral or park. From what I've read when your pads are really hot (like they get from hard braking from high speed) keeping the pedal down could form cementite nodules to form on the rotor and then as you put more mileage on the car the nodules grow in size and brake "shuddering" starts happening.
Excellent advice. :thumbsup: Much like a clutch driving habits can do a lot to extend brake life. And fluid flushes.
As long as the machine isn't bent and the operator knows how to read, measure and use the machine, and gives a damn, turning rotors is OK. I generally just replace em anymore though, $30 ain't bad.
Long as they are in spec printed on rotor I don't have any problem with multi turns myself. . They are either thick enough or not be it from cutting or just wear.
Linkwhat's thick enough?
Nominal Thickness:
Nominal thickness is the thickness of the rotor when it is new. This thickness is not usually used on a daily basis, but is listed in most specification books.
‘Machine To’ Thickness:
This is the thinnest a rotor can be machined to and still be put back into service. The purpose of having a machine to thickness is to provide enough rotor material to last the life of one set of pads. The assumption is that if the pads are replaced and the rotors are over “machine to” they should not experience enough wear to allow them to go below discard thickness through the life of that set of pads. The average difference between nominal and machine to thickness is .050″ to .060″. The typical difference between machine to and discard is .015″.
Discard Thickness
The discard thickness of a rotor is the thickness at which the rotor should be replaced. The common understanding of the definition of discard thickness is that it is a heat-related dimension. It is generally understood that if a rotor is at or below discard thickness, it cannot dissipate the heat generated. This is not correct. Discard thickness is the thinnest a rotor can wear to so that in the event the brake pads wear to nothing, the caliper piston won’t fall out of the caliper housing. It has nothing to do with heat.
