MommysLittleMonster
Haha, I thought this thread related to subs as in sandwiches.
Originally posted by: Kalvin00
12"
or 2 10"s
Trust me, i'm sure you'll eventually be wanting more..
Seriously... what kind of fvcked up sandwich joint would have a differential for 10" and 12"?
I suggest two Dayton Quatro 10s. ^^ Isobarik even. Space saver.
No.. you can have both cones facing out, and wire the second woofer to reverse polarity.
Originally posted by: 95SS
If you have the space for the larger enclosure the 12" would require, get a 12". The increased cone area is well worth it. And thanks to BigPoppa for posting actual facts. I love hearing "faster response". Do some drivers play 40hz faster than other drivers? No, 40hz is 40hz. IMO, larger drivers are preferable, since they require less excursion to produce the same SPL than a smaller driver would.
12"
or 2 10"s
I want to save trunk space so im sticking w/ a single woofer.
im taking it your replying to my statement about tens being quicker to respond. Let me just say I'm not talking about frequency response silly, of course 40hz is 40hz. If a sub played 40hz faster, know what it would be? um, greater than 40hz. When I say faster response, I'm actually talking about attack speed.
I've had both dual boston pro 10's and 12's and the 10's were noticably quicker and punchier and the 12's hit deeper. The tens rolled off at least 5hz higher than the 12's but the 12's seemed to bleed together on extremely dynamic double bass lines (like from Dream Theater).
This is the point at which I will conceded the argument, because I did infact read the adireaudio white paper. Even though this is a single white paper that could be BS, I'll also admit that other factors could have led to me hearing the differences. Slightly incorrect box spec on the 12's leading to poorer response? I don't know. I'm good enough with math to build a box to spec. I just find it hard to believe that watt for watt, a speaker of the same make will be equally as fast to respond at all sizes. I mean, if I have two kids on a swing, and one weights 50 pounds and the other weights 60 pounds, you would think that if I pushed both at the same amount of force the lighter child would swing a little higher. 😉
Originally posted by: Anubis
id get a MB Quart 10in the PWE 254, itll take 400w and has a responce or 18-300
NO NO NOOriginally posted by: TechBoyJK
Originally posted by: BigPoppa
Subwoofer size has no correlation to woofer speed. You can make a 15 sound just as tight as an 8 when played at the proper frequencies. Tightness more comes from the frequencies you're playing. 80-120 is the range of kickdrums. Some woofers play better than others in this range. Technically, you shouldn't be playing a sub that high.
As for the 10 vs 12, go for the 12w3v2. A lot more cone area.
Personally, I'd go with a w6v2. Some people prefer the sound of the w6v2 to the w7.
um, as far as I know, the lighter the woofer cone, the faster it can be? therefore a smaller sub can be faster? i thought this was common logic? if you have a sub, in two versions, a ten and twelve, the ten will undoubtly be faster given all other variables are the same.
http://www.crutchfield.com/S-NEvrluvdMF...i-bin/ProdView.asp?g=67600&I=049PWE254
Not bad for $149, but i would have to get the Alpine 501 ($100 more)
Would it be noticably better than the JL W3?
