0.999999[r] = 1
Any one heard this paradox?
It's some thing from an ancient greek philosopher.
achilles is running at a constant velocity. someone shoots an arrow at him form a given distance behind him. the arrow is travelling faster than achilles. let the time it takes the arrow to catch up to the position of achilles be delta t. during this time achilles moves forward a finite distance, his velocity times delta t, while the arrow has moved to the point where achilles was before delta t. then the arrow moves forward to the position where achilles is now in time delta t2, and again achilles moves forward his velocity times delta t2. this continues infinately and achilles always moves a finite distance ahead of the arrow during each time step
although anyone who's taken physics knows this is wrong, the math seems to make it true
You're just expressing the moment of impact in an infinite sum. Quite the same way in that 0.9(r) equals 1.
Yea, Zeno's Paradox is similar. This site has a bunch of other neat Paradox's as well.
Actually, they're both "Zeno's Paradox"; he came up with several of them. They're basically observations that time and space must be infinitely divisible (although this is not clear until you have calculus to solve the infinite sums cleanly with).
Originally posted by: zugzoog
to then go to the step 10x - x = 9x = 9 assumes that 0.99999[r] = 1 in the attempt to demonstrate that 0.99999[r] = 1
You are correct; this is not a proof, since it relies on the item you're trying to prove being true. However, see my posts above where I discuss the problem in terms of the limit of the infinite sum (9 * 10^-x). That is a proof that .999[r] = 1.
0.0000..09 is my best description of the difference that would result from the subtraction.
See my other post above where I reference 0.000...01 (other people have brought this objection up already) and show that this "number" (which cannot be defined as a real number) must be equal to zero. And if (a - b = 0), then (a = b).
Is Zeno's paradox true? That time and space must be infinitely divisible? If so, than by that definitioni .999r != 1 isn't it, because there must be a division even if we haven't invented it yet as humans
Modern physics suggests it isn't. Space and time are "grainy".
I'm a little fuzzy on low-level quantum mechanics, but I think the gist is that *energy* is "grainy", not necessarily space and time. I may be misinterpreting what I've read, though.
In any case, space and time are not the same as mathematics. Mathematics is a closed and fully defined system. You can prove, mathematically, that .999[r] = 1 (see above). We have no way to "prove" anything experimentally about the nature of space and time, other than by making observations and trying to come up with rules that fit them.
Zeno's "paradox" is only a paradox if you don't have integral calculus, because without it you can't prove that the infinite series has a finite limit. The more well-known one is "Achilles and the Tortoise":
A tortoise starts out some distance d in front of Achilles, walking away from him at velocity v_t. Achilles runs towards the tortoise (moving faster than the tortoise, obviously). How far does he have to run to catch the tortoise (or, alternatively, how long will it take him to catch it)?
When he reaches the point where the tortoise started (position x), the tortoise has moved some distance, so he has not reached it yet (the turtle is now at position (d + t_1 * v_t), where t_1 is the time it took Achilles to move from position 0 to d). But when Achilles reaches position (d + t_1 * v_t), at time t_2, the turtle is not *there*, either, since it takes some amount of time for him to get there -- the turtle is now at position (d + (t_1 * v_t) + ((t_2 - t_1) * v_t)). This will continue indefinitely (the turtle always moves a nonzero distance in the time it takes Achilles to "catch up" to his last position), and thus Achilles will "never" catch the tortoise (hence the paradox). The conclusion to be drawn from this is that time and distance must not be infinitely divisible (since, clearly, you can catch slow-moving objects 😛) -- but this is not the correct answer.
With the mathematics they had at the time, you could not solve this problem fully. However, you can rewrite the equations as an infinite series and, with calculus, show that the time and distance required converge to finite numbers as the number of terms goes to infinity.
Time has a lower limit we know about called the planck time, 10^-42 seconds. That's the smallest amount of time physics knows about right now. As for space, there have been a few papers put out recently suggesting that space is grainy as well, but I can't recall or point you to them.
Something like that elementary school brain-twister that says a man starting at A can never get to B because he can only get to half the distance of each resulting distance from the destination.
I always just figured that the flaw with both of these paradoxes was that the calculation always assumed the destination as being something other than the actual destination stated. The arrow won't stop at the point that Achilles was, it will continue to change position in space in a linear direction faster than Achilles' position changes, therefore the arrow will meet its destination (Achilles) at some point. Just like the man walking from point A to point B isn't looking to stop half-way, he will continue to walk past every half-point and eventually complete the total distance between the two points, resulting in his destination. Or, you could assume that his destination, point B, is half the distance to point C, not the destination. So the paradox agrees with the fact that the man will reach his destination.
As I said, all those "half distance" games are just expressing the moment of arrival in an infinite sum. Nothing wrong with doing that, except that it's a MISPWOSO stylee approach.
Another example: Man walks dog on a five-kilometer path, the man walking at five km/h. The dog runs free, at twice the man's speed. Dog knows destination, keeps running to and fro the destination and the man, in ever more quick oscillations if you dare say dogs oscillate. Question: What distance does the dog cover in his infinitively faster zig-zagging motion?
I'm a little sketchy on it, but I thought that while they were infinitely divisible, as some point, the divisions become absolutely meaningless. Planck's distance, IIRC. (about 1/ 10^20th of the diameter of a proton)
And, divisions of time smaller than the amount of time it takes light to cross that distance are meaningless as well.
Since when could x=.9999......, and also equal 1 at the same time in the same equation?
Oh, and for some reason i remember this being posted in a different thread on the subject : Can you tell me what the smallest number is?
I forgot the significance of this statement but it was posted by someone who disagrees with .99999!=1
Oh, and for some reason i remember this being posted in a different thread on the subject : Can you tell me what the smallest is?
Where have you been hiding the last 50 posts on this subject? Try reading the proofS.
Well...what i meant was that a variable (x) can only represent 1 value in the same equation. That equation that says : x=.9999999
10x=9.9999999999
10x-x=9x=9
9x/9=1
x=1
is wrong because at the beginning x=.99999999 but then x=1.
Oh, and wtf, since when does .3333333=1/3? every 3 you add will only make it closer to 1/3 but it never will equal 1/3
Edit: Oh, i just noticed a typo in my post : I meant: what is the smallest number? but i fixed it so ya
Young grasshopper...you must learn the inner workings of mathmatics:
.3333333 != 1/3 true Were not talking about this....
_______
.3333333 = .3333333[r] = .3333333 repeating forever...an infinite number of digits.
these 3 values are = 1/3.
_______
.9999999 = .9999999[r] = .99999999 repeating forever...an infinate number of digits.
these 3 values are = 1.
Here is another proof for those in disbelief...
1/9 = .11111111111[r]
2/9 = .22222222222[r]
3/9 = .33333333333[r] = 1/3
4/9 = .44444444444[r]
5/9 = .55555555555[r]
6/9 = .66666666666[r] = 2/3
7/9 = .77777777777[r]
8/9 = .88888888888[r]
9/9 = .99999999999[r] = 3/3 = 1
"Hi, I fail to understand the concept of significant digits. I wish to hear arguments about cases where SD are important without actually knowing what SD are. Additionally, any argument must inherently be applicable to any possible context."
lets say you have a body that starts from rest at the top of a building and falls for 10.913 seconds before hitting the ground. if we want to know the final velocity of the body we can use this equation, velocity(final)=velocity(initial)+acceleration*time. assuming that gravity is the only force acting on the body we can say that the acceleration is 9.8 meters/second^2. since the initial velocity is zero, the equation looks like this, v(final)=(9.8 m/s^2)*(10.913 s)=106.947 s. you should use 106.9 instead of 106.947, though, because you weren't given any more information that 9.8 m/s^2 in your original data, so you shouldn't end up with data that is more precise than what you were given.
_______
_______
Take a calculator and multiply .333333333333 by 3. What will your answer be?
C'mon, all of you. You were all told in grade 4 that .3333333 isnt equal to 1/3.
Prewarning... I apologize to everyone else who reads this thread...
Text
Dear:
[ ] Clueless Newbie
[ ] Loser
[ ] Spammer
[ ] 12 year old
[ ] Pervert
[ ] Nerd
[ ] l337 d00d/"vet"
[ ] Other: illegal immigrant
[X] Dumbass
[X] Math Illiterate
You Are Being Flamed Because
[ ] You posted a Nudity thread (anime or normal).
[ ] You whine like a girl.
[X] You lack subject: Math knowledge above the 4th grade level.
[ ] You bumped a thread from the last page.
[X] You posted something already asked a hundred times.
[ ] You started an off-topic thread.
[ ] You posted a "YOU ALL SUCK" message .
[ ] You don't know which forum to post in.
[X] You posted false or DUH information.
[ ] You are bragging about being a scumbag and/or griefer.
[ ] You posted a question answered in the FAQ.
[ ] You posted something totally uninteresting.
[ ] You doubleposted.
[ ] You posted a message all written in CAPS (oR aLtErNaTe CaPs).
[ ] You posted a X > Y thread. LAME.
[X] I don't like your tone of voice.
To Repent, You Must:
[X] Give up your AOL Internet account
[ ] Bust up your modem with a hammer and eat it
[ ] Jump into a bathtub while holding your monitor
[ ] Actually post something relevant
[ ] Be my love slave
[X] Apologize to everybody on this forum for wasting space
[ ] Go stand in the middle of an intersection
[X] Other: Eat your calculus book
In Closing, I'd Like to Say:
[ ] The search button is your friend!
[ ] Get a life
[X] Never post again
[ ] I pity your dog
[X] I think your IQ must be 6
[ ] Take your crap somewhere else
[ ] Do us all a favor and jump into some industrial equipment
[ ] Go play Dress-Up Barbie Online?
[ ] All of the above
take your calculator and shove it up your ass....
now then....
.3333333333 does not equal .3333333333[r]
.3333333333[r] =
.33333333333333333333333333333333333333333333333333333333333333333333333333333333333
3333333333333333333333333333333333333333333333333333333333333333333333333333333333333
v33333333333333333333333333333333 and keep adding 3's until you run out of page...till you run out of universe.... the 3's go one forever until infinity... thats why there is an [r].... which MEANS REPEAT FOREVER and only then...when you have an infinte number of 3s does it equal 1/3.
now please note... everyone of those numbers in my post above has the [r].... which means that.... they repeat that digit forever until infinity...
come on...you were told in 4th grade that if a decimal is repeating forever....it never stops... it repeats forever.... even if your calculator runs out of screen space
sao123, you are an idiot. The reason I didn't put the repeating sign on there is because if you did multiply .3333333333[r] by 3, all the threes would be turned into nines.
[ ] Give up your AOL Internet account
[ ] Other: Eat your calculus book
[X] STFU and get a life, then go commit suicide
futuristicmonkey, it's time for you to admit that you fail to comprehend the concept of infinity, and then STFU.
