- Mar 3, 2017
- 1,626
- 5,908
- 136
You claim that Intel has been stagnant for 10 years, and yet AMD has not managed to significantly overtake uarch. Zen1 barely caught up with Broadwell (Haswell with minor tweaks). If it were that easy, they would have crushed Zen1 by now.
Since 2017, AMD and Intel have been going together like a couple in a dance (Intel sometimes loses its steps a bit).
Are you saying this will suddenly change? I believe that Zen4 is so good that a 40% IPC jump from generation to generation is impossible, considering the project implementation time and the possibilities of the transistor packing process per mm2.
Apple, they did many 20-30% IPC increases in a row despite already having the best core.I wanted to emphasize that in the past, even if there was a very large IPC jump, it was only against the background of the poor solution of the previous generation. Find another example if there was an exception.
To me this “ground up design” assessment (given pretty much to each Zen CPU gen) seems exagerrated. I've always wondered what exactly this "ground up" entails, even compared to the 1st Zen?Zen 5 is the 1st ground up design where AMD have had decent R & D money. They could squander it of course but given their execution record over the last 7 years I don't think they will.
The only Zen gens with ground up designs are 1, 3 and the upcoming 5. Ground up means that the floor plan of the core is being significantly changed. For Zen 2 and 4 it was just expanded upon.To me this “ground up design” assessment (given pretty much to each Zen CPU gen) seems exagerrated. I've always wondered what exactly this "ground up" entails, even compared to the 1st Zen?
Zen 4 includes server. Also, its the 1st generation to include basically a full avx-512. Also, with speed as well as generalization its far from Zen 3 in both departments. And if you add efficiency in server or in desktop using ECO mode, its light years past Zen 3. Speaking from someone who had massive Zen 3 boxes and upgraded everything to Zen 4, including server hardware.Compared to other designs I don't think Zen 4 is that great, it is simply the least bad x86 design.
Based on your definition, each Zen CPU generation is "ground up". But even then, the most radical change in the design was with Zen 2 (not counting Zen 1, of course)The only Zen gens with ground up designs are 1, 3 and the upcoming 5. Ground up means that the floor plan of the core is being significantly changed. For Zen 2 and 4 it was just expanded upon
The clock regression was supposed to happen because Zen 5 was originally supposed to be on 3nm (N3). TSMC (N3) silicon is more energy efficient but sucks at clock speed compared to N5/N4. A bulkier wider core and more bandwidth is not going to affect the max CPU clock speed. AMD will not be on 3nm until a Zen 5 refresh.
For efficiency sake, it would have been nice to see Zen 5 on 3nm.
What is zen3AMD got definitely not a stellar track record of making "brand new things".
Hella lot of post-layout optimisations, Vth swapping and bias tuning, plus new L3 and its ring bus?What is zen3
Is Zen3 really as big of a redesign as Zen1 was?The only Zen gens with ground up designs are 1, 3 and the upcoming 5.
Wrong about Zen 3.Hella lot of post-layout optimisations, Vth swapping and bias tuning, plus new L3 and its ring bus?
In what exactly?Wrong about Zen 3.
Also, what is Zen1?
yea.Is Zen3 really as big of a redesign as Zen1 was?
Recycled infos. IPC/ST uplift, which is the selling point for zen 5, is still missing. SadI don't know if there is anything new here, or just summary of the "consensus"
For Granite Ridge: 2x RDNA3 CUI don't know if there is anything new here, or just summary of the "consensus"
Good catch. Probably a mistake / typo.For Granite Ridge: 2x RDNA3 CU
Previously it was believed to be RDNA2, same as for Zen4. If actually RDNA3, it will mean new IOD, so not same as for Zen4.
But I suspect it could be a typo, since it also says ”Raphael IOD (N6)”, i.e. same IOD as for Zen4.
having RDNA 3,5 clocked at 2,6 - 2,7Ghz means they managed to achieve worse GPU frequency than Phoenix RDNA3 GPU....I don't know if there is anything new here, or just summary of the "consensus"
In what exactly?
Are we talking about the CCX design only or the CPU as a whole?
And don't quite understand about Zen 1
So true, Zen5% has been downgraded to Zen0%.
People are laughing now, but soon I'm the one who will laugh seeing the tears of disappointment.
Zen 5 will be good, yes, but not good enough.
Nope.I'm guessing the 10%ers are as wrong as the 32%ers
I don't think either side will be crying but cherrypicking.
