Zuni: Search problem
techfuzz
I'm a subscriber if that makes a difference based on which search is being used.
I tried searching the Off Topic forum only for the word "alcohol" (w/o quotes) and got back the following error:
Sorry, an error occurred while performing your search.
Error Code: 109
techfuzz
Also, it would be better to have both a "clear all" and "select all" button with the forum categories. To select all categories, you need to click twice (and double-clicking won't work, as it's too fast for javascript 😉)
Double post because I got this error when replying.
Forum Error
An error has occurred. If you wish to notify the administrator please click here.
To go back to the main forum page please click here.
ERROR INFORMATION:
An error occurred while evaluating the expression:
Message = "#FTVAR_DISPLAYNAME# has posted a reply to the thread entitled #CHR(34)##qGetThreadInfo.vchThreadName##CHR(34)#.#CHR(10)##CHR(13)#You can view it at: #FTSET_FORUMSURL#/messageview.cfm?catid=#catid#&threadid=#FTVAR_THREADIDTMP#"
Error near line 39, column 10.
Error resolving parameter FTVAR_DISPLAYNAME
ColdFusion was unable to determine the value of the parameter. This problem is very likely due to the fact that either:
You have misspelled the parameter name, or
You have not specified a QUERY attribute for a CFOUTPUT, CFMAIL, or CFTABLE tag.
The error occurred while processing an element with a general identifier of (CFSET), occupying document position (39:4) to (39:339).
Also, it seems we're no longer able to search by author. Instead of using the Today Page, I preferred to simply type an author's name in the box, select all forums, and I could easily keep up with my posts are anyone else's. I get the same Error 109 code when trying to do this under FuseTalk 4.
This is just because its re-indexing the db right now so thread titles are searchable using fulltext, it could take a few hours.
