Originally posted by: elzmaddy
Press ALT+TAB or CTRL+ESC when you start the game, switch to ZoneAlarm and click YES on the popup (and also check the box). If that doesn't work, just set internet firewall to LOW while you are playing the game.
Originally posted by: BennyD
no they will not
Originally posted by: Angrymarshmello
Unless you're using the first ever version of ZoneAlarm, these steps will work. Stop being such a dumb ass and learn how to use it.
no they will not
yes, they will.
no they will not
yes, they will.
listen assmaster, you show me how to do that using this this picture, then i'll shut up ok?
Originally posted by: Sid59
are you always this nice to people who try to help, troll?
and repeating the same advise after i have said it does not work is help how?
i am trying to play the tron 2 demo online but i can't get it past zonealarm, when i try zonealarm thier to popup and it hangs
anyone know how to add it to the program manually?
