I am running a dual boot system with 2 W2K installations, each on a different HDD, I swap between the installations by changing the BIOS boot order.
I am getting the following message, at boot, in both installations:
C:\Program Files\ZoneLabs\ZoneAlarm\zlclient.exe - at the top of the error boxes.
In the boxes: C:\WINNT\system\VSINIT.dll You probably are missing a necessary root certificate
& same path ...vsdata.dll same message.
I'm about to do a re-install to try and clear the problem on one installation but I would really like to keep the other installation as well.
Both HDDs were scan for Viruses and none were found.
Is there a way of re-registering the root certificate?
