Zip Drive not recongnized by Bios PLEASE HELP!!!!!!
kehi
3,357
I have a Zip 100 drive on my Asus P3V4X mobo and I can not get win98 to see it as a removable disk drive like it should be. It shows it as 3/1/2 Floppy D. It is assigning the correct drive letter but the name is incorrect. The drive is on secondary slave and I was told by an Iomega guy before to disable that channel in the bios and I did that it still did'nt work. I appreciate any help you guys could give.
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
If Im not mistaken that drive has a jumper setup on it to allow it to be seen as B drive... check the jumpers to be sure it is where you want it to be set.
