S scaryfast Member Jul 3, 2008 97 0 0 Jul 29, 2008 #1 ZEROtherm BTF90 with manual fan controller (BTF92) The Owner's Manual doesn't say. The specifications do not say anything other than it is Manual Control. I'm hoping you have used one and can let me know. Cause I want auto control also. Thank You
S scaryfast Member Jul 3, 2008 97 0 0 Jul 29, 2008 #2 I found a site that says "The fan can be plugged directly into the motherboard header". Does that mean it would have Pulse-Width Modulation control like its brother the BTF90 does?
S scaryfast Member Jul 3, 2008 97 0 0 Jul 29, 2008 #3 I see it uses a 3-pin connector. The one that is PWM says it is a 4 pin.. Doe that enlighten in anyway?
