poptodafresh
hello, been frequenting the forums for a while but a computer problem is what got me to finally set up an account
i seem to have a bit of an odd problem and ill walk through the steps of what happened including my train of thought
1) come home one day and oddly enough, as much as i press the power button...nothing happens...no beeps...no power whatsoever
2) i start rummaging through my parts with the initial belief my power supply has gone out, but the motherboard is powered and when i pulled out my video card, full power was given. Also when i unplugged the power for long enough for the mobo light to turn off, when i plugged in and hit power, the fans rotated once and stopped.
3) i now believe my video card could be causing inexplicable problems so i plug in a perfectly fine card and the same problem is repeated.
4) i now believe the mobo might be failing so i switch in a perfectly good mobo (yes i have many parts lying around) and try to start up. the fans rotate once and then nothing.
5) stumped, i plug in the video card again with the same results...nothing...take it out...the computer now boots up fine though with no video.
6) confused, i post here asking for help.
From what i can tell, it seems that my mobo is not the problem, and even with a perfectly fine video card i cant get any kind of startup. also, there are absolutely no beeps and i have already checked RAM and the other parts except for processor. Power is being given, as seem by the computer starting up, though when a video card is in, nothing happens...whether or not the video card works. possibly the proc?
If you can do anything to help, i would appreciate greatly. hopefully im just being an absolute fool about my problem. thanks for reading this
