watdahel
I had two harddrives on one IDE cable. I used the slave drive as a backup for my porn collection. Anyway, my master drive is started to act up and I decided that I should install winXP on the other drive in the event that my main drive craps-out I can just switch drives and be back in business. Yesterday, I connected my backup drive as master on the IDE by itself and proceeded to install winXP. I didn't want a dual boot option that you would normally get when the installer sees another drive containing a winXP installation. I could just go to bios and select which drive to boot first.
The installer started copying the contents of the CD on the drive and restarts. This is where I reach a deadend. It tells me it's unable to load operating system. I repeated this five times, trying out different pin configuration on the drive, reseting the bios, switching IDE cables, install win2000, and sprinkling pixie dust all over. Each time it's the same retarded result. Everything works fine when I reinstalled on my main drive.
I reconnected both drives as before and the slave drive does contain a Windows folder that the installation copied over.
I don't know.
I don't know.
