Zenith DVB612 1080i Up-conversion DVD player 39.99AR
Lorax
1,658
almost jumped on it, but only outputs audio in stereo format...
EDIT: NM, it seems to do others too. getting conflicting specs.
luv2liv
3,498
94
can it play +r, -r?
i love my phillips 642. it plays everything, all regions!!
lsman
3,869
www.flickr.com
I try -r, it works.
videohelp.com have some users reviews said +R ok.
Don't have the HDMI cable so using component, it can up-scale to 1080i on non-copy right DVD. But I don't notice the different... between 480 and 1080...
The front, right side has 3 buttons. But the middle button don't have any function related to it.
The power on and reject is on top, so it may not work if you have others AV stack on top of it.
Not too impress with the initial read time (from load to start play)
Have not try Divx yet.
niji1875
579
is it can play all regions? i want to buy better one.but when i see this one,i may think about one day
lsman
3,869
www.flickr.com
manual said: play the region on the back of the player labeled (which will be US, 1) or play DVD that has "ALL"
hasn't see any hack to play other regions
