Page 816 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Hitman928
6,122
10,523
Probably they were testing it in a 100% gpu bound scenario (aka if you don't set grass to extreme, for example)
Paul’s hardware didn’t show the issue despite it not being GPU bound.
The Anandtech Warhammer result is probably the closest data point we have that shows a potential issue, but the fact that it’s 1 data point, the 9900x is outperforming the 9950x in their test, and no one else that I’ve seen seems to see the same thing in that game, leads me to believe it’s an issue in Anandtech’s testing. Wouldn’t be the first time, they’ve had lots of issues in their reviews over the last couple of years. Unless someone directly tests for it though, we’ll never know for sure.
MS_AT
219
521
At least one of them is taking great care to test in cpu bound scenarios. Now I don't have a game and haven't tried to reproduce their results. This is a Polish internet site, I could link to that is also having them equal.
Jan Olšan
400
689
Intel also benefited from the patch, just not as significant as the Ryzen. It's now only 3% behind, whereas previously it was 5% behind.
If it does it's error in testing and it's effect of some other change. The codepath should be AMD specific and Tom's Hardware's retesting found 0% change on Intel.
Remember that HWU also reported those crazy 30% outlier results (that were also clearly result of some other factor).
Jan Olšan
400
689
TPU tests ST power numbers. Maybe they'll do updated testing, but I doubt it. Their graph is why I figured it was a power saving feature to begin with:
Hwcooling tests power consumption by physically measuring draw on the 12V cable feeding the VRM and found idle power to be higher, not lower.
If the CCX latency thing improved power, it was not enough to offset the difference.
Instant idle power depends on the whims of the operating system and background processes a lot, so numbers are often going to be inconsistent gen-on-gen though.
Reactions: Josh128
Hitman928
6,122
10,523
That's why I used ST power, not idle power.
Edit: BTW, I'm not convinced the latency issue is from a power saving technique, it's just speculation that makes sense to me and seems to be supported by TPU's ST power results, though that could be due to some other factor.
biostud
18,667
5,395
The crazy thing is had AMD released the 9700X as a 105W chip and it had the additional 10% uplift, no one would have cared what the results were at 65W. But since it was released at 65W and reviewed that way, now all anyone will talk about is the cost of the performance increase, i.e. 40% more power for only 10% more performance.
Then they should just have released them without the X in the end. The inconsistency and misleading numbers from AMD's marketing is not doing them a favor in "our" community.
Jan Olšan
400
689
Oh sorry, seems I should have paid more attention. In that case the audio encoding numbers (commandline FLAC task, strictly 1T) in the link would be applicable. Seems the dual-die SKUs actually also show increase in power in the test. Only 9600X had lower power than 7600X (for the board+memory and samples/condititions used in the test).
Reactions: Tlh97 and Hitman928
Josh128
348
475
Not only that, R23 for their 9950X was around 256W vs 217W for 7950X for a score of 41.6K for the 9950X vs 36827 for the 7950X. The 9950X is not what HWinfo64 shows as PPT for default operation, but the R23 score is. What gives?
Markfw
May 16, 2002
26,129
15,274
I know others have said the r23 does not use avx-512, but maybe it does ? Regardless the instructions sets are different on Zen 5 vs Zen 4, and the ones it uses in R23 may use more power, just like avx-512 does.
Josh128
348
475
This goes counter to every other review Ive seen thus far, which says 9950X PPT is around 199-200W during the R23 nT run, while the 7950X is around 220W.
Det0x
1,262
3,991
Default PPT power limit for the 9950X is 200w
I would know.. have already binned a few ;)
The only way i could see ~250w being right, is if they are messuring from the 12volt EPS cable (includidng the VRM powerloss), but this is not PPT power limit
gdansk
2,890
4,363
Did you ever run one at 230W but otherwise stock? Curious if that last 30W does anything. Or if that's why AMD cut it.
Hitman928
6,122
10,523
It does seem like something weird is going on with their power measurements. Perhaps their board is doing something weird with the Zen 5 voltages that it isn’t supposed to do?
They are measuring at the cable, but that still doesn’t explain why the Zen 4 CB power numbers are significantly lower. At worst, they should be equal.
Reactions: Tlh97 and Josh128
Abwx
11,536
4,323
Their 7950X doesnt perform accordingly, at stock Computerbase got 38649 pts in CB R23 for about 205-215W, 5% better than this one that is eventualy subject to some thermal thorttling wich explain the lower perf and comsumption, btw at stock Computerbase got 189W in Handbrake despite being at the helm for this bench, actualy the 7950X never reach it s 230W limit.
Jan Olšan
400
689
As for the 7950X CB23 MT performance, according to the reviewer that processor gets limited by cooling before it gets limited by its PPT, in that test. The review methodics is locked on using Noctua NH-14S air cooler for all processors, so you could get better results with cooler that manages to get the temperature of 7950X down (good AIO?). The changes in Zen 5 cooling (or temperature reporting...) enable the 9950X to not be temperature-limited with the same cooler though.
The power reading on 12V cable includes all VRM losses in addition to the CPU's "wattage". Hopefully they should be similar % all the time, but the % might vary based on load and so on. However, with the power reported by HWiNFO, you are at the mercy of the sensors and you also don't know how reliable the reading (or its interpretation by the software or the motherboard itself) is.
I'm sceptical of the 200W PPT figure for 9950X that is being passed around for this reason, if it is only a conjecture based on empirically observed power. As you know, power you see varies on the task that is being run and i the past, there were processors that weren't hitting their maximum PPT for example due to running into current limits sooner than the maximum PPT was exhausted (or into their frequency ceiling on SKUs with less cores).
Do you base the 200W on observation? For the above reasons, I would be very careful with that. The PPT should be a value specified by AMD and observation may or may not match.
I really wish AMD would clearly state the PPTs for SKUs in their official specs. Perhaps people should (politely) petition for that on AMD subreddit and Twitter...
Cllaymenn
18
21
41
WOW!
After hearing rumors about newest beta agesa 1.2.0.2 improving both performance and latency i decided to put it to the test!
I downloaded and flashed to newest ASUS bios 2401 and ran capframeX core-to-core latency
And wow indeed, the wispers were true, with agesa 1.2.0.2 AMD have finally fixed the core-to-core latency plaguing the 9000 from launch
This is with agesa 1.2.0.1A bios 2303 = cross CCD latency is ~180ns
Now with agesa 1.2.0.2 bios 2401 = cross CCD latency is ~75ns
Otherwise 100% same settings used for both runs, will be interesting to see how this affect the gaming performance / latency bound benchmarks :cool:
Can you do some test like CPU-z Bench, AIDA64 GPGPU (this test tells a lot about the performance difference because it uses various calculations, I have results from about 3 months ago on 9950X IE to compare)?
Det0x
1,262
3,991
I'm rebenching 7000 series for hwbot atm while i wait for new delid frame for my delidded 9950X, so it have to wait.. But 7zip is first on my list when i get my Zen5 system put back together.
But i can share one other little interesting thing.
Pre agesa 1.2.0.2 it was recommneded to use the "X3D core parking" meta for Zen5 dual CCD cpus, for best gaming performance.
Now with fixed cross CCD latency fixed ob agesa 1.2.0.2 you actually get higher performance with not using the core parking (high performance powerplan)
Following screenshots belong to other guy from overclock.net forum, so this will only serve a preview:
CCD1 parked -> game is running on CCD0 only (balanced powerplan)
Core parking disabled -> both CCD enabled (high performance powerplan)
He will share more games when he is done with testing
MS_AT
219
521
But i can share one other little thing interesting thing.
There are 2 Polish publications that reported the same in few days after 9900X / 9950X launch so before the AGESA update. But most media outlets at the time were more concerned with special admin accounts, etc so this thing was forgotten. Now if they retest I guess it will be attributed to inter-ccd latency fix;)
Det0x
1,262
3,991
And he have made his findings public 👍
Apart from WUKONG which seems to be the same or within margin of error, the all core approach now shows better results, then what was previously considered to be the best (parking ccd1). All the other tests were showing quite an uplift in the CPU and overall scores.
Det0x
1,262
3,991
but did he even tried to test before core parking on/off before bios update?
Yes, he even wrote this in the linked post above
So far up until now, we have seen that parking (even though mostly for x3d chips) was also beneficial on this new double CCD CPU. Previously I had worse results when using the unparked approach.
This is the third time you are trying to downplay the effect of this new agesa i believe, any particual reason for that or ?
Seasoned actual AM5 users/overclockers are saying that with this new beta asus bios 2401, they are getting improved performance, both on single and dual CCD cpus, but its almost like you dont believe them (?)
Or maybe its just me thats reading too much between the lines, dunno
yottabit
1,491
522
Found Starcraft 2 test. Zen5 have advantage over Zen4 non X3D
Also Escape from Tarkov
Wth is up with those SC2 framerates? It's 2024 and top end CPU can't run that game faster than 100 FPS?
Do they have some crazy custom map benchmark or something? Or did Blizzard just bloat it to the moon? Still running DirectX 9 too?
I remember playing SC2 beta in 2010 on an i5-750 and it ran good enough to get me to Diamond rank
