Page 684 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
adroc_thurston
3,533
5,095
Not in the sense of being a completely uncompetitive product. It looks like AMD made some odd choices, tried some new tricks, and performance is kind of underwhelming, but it's not meaningfully worse than Zen4 on any axis and is better on some others.
Yeah, this is like Cortex-X3, massive changes for meh bumps.
Kinda ass.
Perhaps they really wanted to ensure perf/watt at the very start of the curve is competitive, so they increased the -C core count. I agree though, I'm confused about the P+E core arrangement too, and I'm really surprised out of the couple interviews with AMD employees we had, no one really asked them about this...
It's cost.
GTracing
88
202
Folks making the Dozer comparison need to remember that Intel was doing 50%+ more iso-clock ST int against it.
I would add that Bulldozer used more power than it's predecessor and nearly twice as much as Sandy Bridge. Zen5 has quite decent power consumption.
LightningZ71
1,792
2,151
The arrangement makes more sense when you remember the other rumors for Strix Point. It was supposed to have a decent chunk of MALL cache that got axed for the larger NPU. That MALL cache makes Strix Point look a lot mire like Alder Lake/Raptor Lake to an OS scheduler, with a combo of faster cores with large L2 and a slight latency hit last level cache (L3 there) and a group of more numerous, slower cores that have more limited cache (shared L2) with similar access to a hugher latency LLC.
In the universe with the MALL cache, the split CCX, limited cache arrangement makes more sense. If they had gone with a single CCX with 4 X zen5-512b cores and 4 x Zen5c-512b cores with 32MB L3, and completely ditched the last 4 Zen5C cores, they would be in about the same footprint on the chip and likely have fewer performance oddities while having situations with much higher performance due to the big 32MB L3.
SarahKerrigan
735
2,035
Yeah. BD was a massive misfire. It was not "oh, well, it's only a few percent faster than its already-very-competitive predecessor in slightly-moderately lower power." It was "runs very hot, loses by a massive margin to Intel on ST and barely hangs on with MT despite double the core count."
It was dire.
jdubs03
803
408
No. Zen 5 isn’t bulldozer but it’s also not the mythical core that Apple etc will take years to catch up to. That assertion still annoys me.
I think the M4 is that mythical core for now. I suspect the M4 Pro/Max will be quite impressive.
Btw I found this… 1207 pts in CB24 multi-core (performance mode).
biostud
18,667
5,395
Since there has been made som z790 boards with camm2 slots does AM5 chips in theory supports camm2 modules or will it require a new CCD/memory controller and socket?
Reactions: Joe NYC
gaav87
120
159
Is the chinese leak for the recall TYPO legit ? Im 13% faster in avg and 54% in minimum fps then that 9700x on 5800x3d in cyberpunk ? If its true then im kinda pissed. 1722198345433.png
StefanR5R
5,913
8,820
So it is indeed Zen5%.
Regressing in the GCC subtest after all the accolades about that zero-bubble, 2-branches BPU with 16k L1 BTB... Jesus, this is Bulldozer vibes.
Reminder: For comparison of core generations, variable clock runs on different laptops are not as informative as
  • fixed clock runs,¹ or
  • variable clock runs but with task energy measured, or
  • not as good but better than nothing: variable clock runs but with clock speed histogram.
No use to get all emotional before measurements of this kind become available.²
________
¹) Or even better, fixed clock runs with task energy.
²) Clock speed histograms for Cinebench 2024 are reported by Computerbase, for a start.
I think I read that Mike Clark said they worked on four different Zen 5 designs?
z5c-256, z5c-512, z5-256, z5-512
In addition, z5c-256 (edit: Strix Point) and z5c-512 (Turin-dense) are on different process nodes.
And Andreas Schilling claims that Strix Point (z5-256+z5c-256) and Granite Ridge (z5c-256) are on different processes too (N4P vs. N4X).
I am idly wondering if FPU datapath widths is really the only microarchitectural difference between the designs. (I.e., aside from differences at uncore — such as L3$ size per CCX and IF width per CCX — and at the physical design.)
SarahKerrigan
735
2,035
Stages of an AMD Microarchitecture's Hype
  1. Wild exuberance and extreme optimism toward rumors
  2. Dismissing of less positive rumors
  3. Core is announced; looks mid
  4. AMD must be sandbagging the numbers; the real ones will be higher
  5. ES numbers leak
  6. Perf is mid, it must just be because it's an ES
  7. Core launches and is reviewed; proves to be mid
  8. Compiler/application optimization will improve it! Anyway, the next one will be amazing!
  9. Go to step 1
adroc_thurston
3,533
5,095
  5. ES numbers leak
  9. Go to step 1
now that's cope, roll the clock back and see what people expected from Z3/Z4.
Jan Olšan
400
689
Is there any review measuring power draw during strictly single-thread tasks? (To see the ST boost power of a single core.)
Edit: https://www.computerbase.de/2024-07.../#abschnitt_der_amd_ryzen_ai_9_hx_370_im_test
Apparently is runs single core Cinebench R24 at 18-20W SoC Power, which isn't worst. At least in the Zenbook S16 device tested.
It doesn't quite sustain its maximum ST boost 100% of time, it starts at 5.1 GHz but then drops to 5.0 GHz over time. (People keeping boost on and "calculating" IPC by dividing performance by assumed clock like AnandTech used to do in the past may get wrong result).
You probably meant unit widths by "datapath", but incidentally, load/store are kept 512bit on the 256bit variants.
Josh128
350
476
Is the chinese leak for the recall TYPO legit ? Im 13% faster in avg and 54% in minimum fps then that 9700x on 5800x3d in cyberpunk ? If its true then im kinda pissed. View attachment 104072
Must state the obvious obligatory different GPUs, but further than that-- does anyone remember some techtuber/leaker saying they saw something really weird in CP2077 with either Zen 5 or 9700X (dont remember which)? Somebody help me, I cant recall who it was but I distinctly remember it. This could be what they were alluding to.
SarahKerrigan
735
2,035
Yes, a rather unique slip.
Now let's see Paul Allen's Zen4.
All I suggest is that perhaps next time you should be less confident and aggressive about things that turn out to be hilariously wrong.
I actually think Zen5 looks decent, as an intergenerational bump, but it bears no resemblance to what you were hyping.
adroc_thurston
3,533
5,095
They've been doing beat and raise in CPUs since the OG Zen.
Even Z4, the nothingburger tick was that. Come on.
PPA-wise it does not crimes but 1t CAGR is severely lacking.
Josh128
350
476
Kinda ass.
It's cost.
The weird thing is, apparently they have a 16 core CCX design completed presumably for use with some form of Zen 5. Makes you wonder why they went 4+8 when they could have apparently done 8+8 on same CCX for Strix. 4 extra cores doesnt seem like it would have busted the area budget?
CouncilorIrissa
529
2,048
1722200071294-png.104074
The Unique Slip 2: Electric Boogaloo (granted that was a GPU).
I'll show myself out.
