- Mar 3, 2017
- 1,747
- 6,598
- 136
Think it only comes down to that those two amd guys arent really good tuners. They simply have bad efficiency/optimizations on all their runs compared to "real overclockers" (that video is only for showcase and PR afterall)Me too. So the numbers from AMD event (42k stock, 44k PBO, 45.5K Curve Shaper) could be true. But this still is like the best ES ever.
Inb4 new AMD marketing metric vs. Intel: how many seconds of benchmarking the CPU can run before it goes kaput.I wonder how many seconds it can operate like this before it dies?
secondsI wonder how many seconds it can operate like this before it dies?
This screenshot that is beeing spammed on wccftech is incorrect:Think it only comes down to that those two amd guys arent really good tuners. They simply have bad efficiency/optimations on all their runs compared to "real overclockers" (that video is only for showcase and PR afterall)
We went throught the same with Zen4(TR) before release, where they showed LN2 runs and "xtreme OC", only to get smashed by prettymuch everyone on hwbot (even those with much worse cooling)
But that stock 42k i can believe, its only their PBO/PBO CS numbers i dont have too much faith in..
And whois to say AMD didnt change their "TDP formula" for this release ?
"170w TDP" could very well mean a 200w PPT limit this time around
Remember TDP for cpus is a made up number
AMD Ryzen TDP Explained: Deep-Dive on TDP Definitions & What Cooler Manufacturers Think | GamersNexus
stub Thermal Design Power, or TDP, is a term used by AMD and Intel to refer in an extremely broad sense to the rate at which a CPU cooler must dissipate heat from the chip to allow it to perform as advertised. Sort of. Depending on the specific formula and product, this number often ends up a...gamersnexus.net
At 13:39 in the GamersNexus video the guy said hes running 5ghz all core at 1.35V (but he could run it at 1.1V at the current temp of -69C(nice) with a score of 43375 and he said i quote:
"This is what you could call mission mode STOCK mode"
Not that it matters much, but in the ES 200w PPT screenshot you can see the cpu running ~5.1ghz @ ~1.080vseconds
At 13:24 in the GamersNexus video the guy said hes running 5ghz all core at 1.35V (but he could run it at 1.1V at the current temp of -69C(nice) with a score of 43375 and he said i quote:
That's indeed what it draws.Didnt hassan post on X about a 9950X using 19x watt running cooler awhile back ? (before all these ES leaks from this forum)
Which could very well mean "170w TDP" could mean a 200w PPT limit this time aroundThat's indeed what it draws.
Seems thermally-limited which is kinda funny.
And who's to say AMD didnt change their "TDP formula" for this release ?
That’s like 10% higher than the results we’ll be seeing on the 31st.Yeah, also the leaked numbers from the AMD event were 42k stock and 44k PBO. No way this ES does 46k. Something is off.
I was talking about some people who argue and post this screenshot as proof for "who knows what" or simply to mislead "normies" and then the "normies" or people who dont have time to follow this take this 41.9k pts number as real "stock" and ITS clearly not.Not that it matters much, but in the ES 200w PPT screenshot you can see the cpu running ~5.1ghz @ ~1.080v
*edit*
Didnt hassan post on X about a 9950X using 19x watt a while ?
Think i saw it earlier today but cant find now
190-ish.Which could very well mean "170w TDP" could mean a 200w PPT limit this time around
Yeah.890M with its four extra CU cores should beat that 3050 then. At 40W of course. That's really quite impressive.
190-ish.
The PPT is 230W but current/thermal limits are hit first.
Very mobile-driven approach but makes sense.
Yeah.
Unlike RMB/PHX (whoever said that meme should stop), STX1 is actually bandwidth-limited.
This thing was intended to have SLC, after all.
Did he delid the CPU?Think it only comes down to that those two amd guys arent really good tuners. They simply have bad efficiency/optimizations on all their runs compared to "real overclockers" (that video is only for showcase and PR afterall)
Strange conclusion..View attachment 103269
water temperature below 10c for sure.
Ryzen 3000+Inb4 new AMD marketing metric vs. Intel: how many seconds of benchmarking the CPU can run before it goes kaput.
How about virtually infinite ! My 7950x's run 100% load 24/7 and have done so since I got them the day Zen 4 was available for purchase. at stock on air.Ryzen 3000+
What kind of air cooler do you run? I was just told by a few geniuses that you cant use an air cooler on a 7950X at full 230W PPT.@igor_kavinski
The 230W, 253W, and Unlimited PPT runs are all effectively the same (peak PPT observed never exceeds 230W). The scores decrease slightly as I continue to increase from 230W to unlimited. This is because my small room is heating up from testing and the air cooler definitely hits the 95C throttle point during the runs at 230W and above.
What model of coolers do you run?How about virtually infinite ! My 7950x's run 100% load 24/7 and have done so since I got them the day Zen 4 was available for purchase. at stock on air.
Noctua U12A.What kind of air cooler do you run? I was just told by a few geniuses that you cant use an air cooler on a 7950X at full 230W PPT.
Core temperature can’t lower than ambient temperature. All ways higher. You can see at 40w load core temperature still 21c, but yours is 38c.Strange conclusion..
This is my noctua air cooled 7950x i have in my living room.
L3 idle temp is pretty much the room temperature even with silent air cooler
And while i'm at it, a r23 MT run
