I may have missed this, but were there any assumptions on whether Zen 6 will require a new socket?
Just curious of what actual AM5 lifespan is.
Zen 6 will likely still use AM5.
I'm afraid there would be no Zen5 at January. Only teaser.
OTOH, few months ago Zen5 DT completion had been already planned to be Oct-Nov, mass production could happen at this timeframe, and there were about 4 months gap between completion to release since Zen2, so you can expect the actual release could happen in 1H2024 or even as early as Mar-Apr.
Mass production could even happening right now when I type this message.
Oh I didn’t mean to imply as much. “Announce” was what I was referring to, though you are right we could just get a teaser. Usually parts follow the announcement after a period of weeks or months, so March - May are probably good bets. I have not actually seen any solid leaks for that timeline, however. The only leak I have seen that was reliable indicated late 3rd quarter.
Also doesn't disprove that there are instances where a change can both increase IPC and reduce power consumption, which is very obviously true. Practically anything that reduces the need to move up the memory hierarchy may do that, or anything that reduces communication distances/hops, and of course not all work is created equal and it's possible to do more or less work to achieve a result. A more general approach to finding a result can both perform worse and consume more energy than a more specific approach. It's of course possible to do more work with less active transistors and vice versa. And then there's pipelines, branch prediction (which is huge, mispredictions are extremely expensive), OoO etc.
It's not a claim any engineer would make.
Very rarely will that ever be the case. When it is, the issue is usually either a failure to optimize the first iteration or the introduction of new power management features (or both)
Absent those two things, increasing IPC means increasing transistors, which means increasing power consumption.
Oh, and regardless of what you think of
@adroc_thurston , note that I AM an engineer. I used to build some hardware products for a living, but these days it is all software, (though I did build a 6502 system on a breadboard recently, and I do have a product I am working on outside of work that is hardware, but not chip level stuff). I am also a tech veteran, having been building PCs since the late 80s. I also have an A+ cert and many other certs, used to work in IT (I do mostly web development these days since it pays very well) and have quite a few industry contacts, just very few that could (or are willing to) give any inside info.
What AMD did with Zen 3 is actually pretty unheard of in the industry. However…
Zen 3 vs. Zen 2
- 19% IPC increase
- same node class, but improved
- slightly higher clocks
- bigger die
- ISO power
- right in our face
The biggest problem in this thread isn't this discussion point though, but rather whether folks around here are going to accept the rude verdicts of a poster as gospel or demand the minimum of proof and decorum.
Zen 3 is a perf/watt champ, but those charts show exactly what we are referring to. IPC is up, but so is power. That is why the big upgrades often happen after node shrinks. Shrinks drop power/die area, increasing the budget for more transistors, which allow for IPC upgrades.
To be honest I'm sort of baffled of how people here treated mlid like he's an anti-christ. He definitely has good infos and people who are into tech news watch him religiously. Right after a new video is posted, a member linked that here almost instantly. I used to think people hate watch him but my opinions have been swayed.
- He makes stuff up all the time.
- He has deleted videos where he made stuff up and got it wrong.
- He also spins his failures to make it look like products were cancelled, etc.
- He is not a tech person, so often he doesn’t understand what he does see.
- He will do/say anything to get views, because he makes money, and that is the only reason he still exists.
Most valid leaks are found in other locations. I’ve yet to hear/see a single one that came originally from one of these YouTube “leakers”.
There are some folks on this forum that know A LOT about Intel/AMD’s release plans, and I am sure they die a bit inside every time he gets quoted.
