- Mar 3, 2017
- 1,608
- 5,816
- 136
Before Zen4 was revealed we assumed the cloud variant was shrunk with regard to the N7 to N5 transition having 1.8x density. So squeezing 16-cores into the same space seemed do-able.
Now that the cloud variant is expected to be a N4 shrink...
N4 to N5 gives 1.3x density.
Again, there's no current evidence that they're using different libraries. "Dense" more likely refers to "dense compute", i.e. the market Bergamo is targeting. They wouldn't tie the naming to library choice like that.The Zen4c(Cloud) is a TSMC N5 Product, But using TSMC High Density Libraries.
Where're those numbers coming from?They need to fit around 11B transistors in an ~80mm² CCD.
You're assuming the cores need the same amount of transistors for the same uarch. I wouldn't make that assumption.Zen 4 is 6.58B transistors. Zen4c is double the cores but same amount of cache so 13B - 2B for 32MB cache is 11B or there abouts.
They are quite different. Laptops highly value bursty, single core speed, hence similar design priorities to the desktop designs. For the market Bergamo is targeting, it's all about throughput.Laptop and server requirements are very similar. So why wouldn't AMD use the same library as phoenix for Zen4c.
Yes because I am trying to get to a 'is this doable or is something else different' position, not this is the Zen4c transistor count and die size to +/- 1%.
So APU transistor density, estimate for Zen4C transistor count and you have a CCD that is sub 80mm based on an 11B transistor CCD. Totally in range of what will fit with 2 IO dies on the Genoa package. The Zen4 94M xtors per mm library though would mean a 117mm^2 die size which is getting to the point, when paired with 2x io dies of being too big to fit.
In addition there is Siena which also uses Zen4c to make the package smaller. This will support 64 Zen4c cores, given AMD like to re-use stuff then why not design the Siena IO die with enough links that it could talk to another one and boom, we have Zen4c used in 2 designs, low end Siena and high end Bergamo as well as the IO Die being used in both segments. It would be so typical for AMD to do this because this is precisely why AMD went to chiplets. Again here though 117mm^2 per CCD with 4 of them would be a tight fit where as 4x 80mm or less is a much easier fit.
What else is obvious for AMD to do. Well the APU CCXs have always been density and power optimised because they are usually built on the best node AMD are currently using and because they are designed for laptops where power efficiency and battery life are key metrics. Power efficiency being a key server metric and density being key for Zen4c makes this a perfect candidate to design the 2 CCX zen4c part. It would save on R&D to re-use that CCX block for Zen4c which is AMD SOP.
I may be wrong of course but it makes sense strategically and it fits with how AMD have operated for the last 5 years.
The interesting thing to me is the impact for Zen5 and Zen5c. It would mean the desktop Zen 5 IO die would need 3 links so it can have 1 per CCX. Has there been a die shot of the Zen 4 IO Die yet? Looking at its size vs genoa (just under 1/3, 122mm vs 397mm) it would make sense if the Zen 4 IO die has 3 links like a quarter of the Genoa die would + a bit extra for the iGPU so it looks like the current IO die may have this already but if not it would need a new one for Zen 5 if the plan is to go with a mix of Zen5 CCDs and Zen5c CCDs.
I’ve mentioned that Zen4c is using HD libraries, and certain folks tried to tell me I was wrong. I suspect it is because they hope Zen4c will come to desktop. A chip using HD libraries is going to top out well under 4ghz, which of course, goes against that narrative. Time will tell who ends up being right.
We will also see if AMD takes the hybrid approach with Zen 5, or if they simply double down on core counts. (8700x -> 16 cores, 8900x -> 24 cores, 8950x -> 32 cores)
If they need to save die area, they will go the hybrid approach. If they can fit twice as many cores into a similar die area, possibly by redesigning the L3 cache into a hybrid L3/L4 stacked cache, I could see them doing that. Half the L3 cache, add a 32-64mb shared L4 cache to the IO die. Profit.
32 Zen 5 cores would likely beat any 8+16 design Intel could come up with. A hybrid approach might not.
The APU tops out at 5.2Ghz on the cores and 3Ghz on GPU at 140M xtors per mm²
That seems dense enough and fast enough to be the basis for Zen4c and I see no reason why AMD would use a different library. The CCD will have a minimum size to fit the physical connections required to wire up the CCXs to the IO die.
Obviously when you put 128 cores onto a chip clock speeds are going to be lower due to the power per core (360W / 128c is 2.8w per core before you factor in what the IO Die uses).
If that CCD were to be used in a desktop Zen4 hybrid product then with about 3x the power per core I don't see why it can't clock like the APU can.
I expect the same to be true for Zen 5.
You are assuming the APU uses Zen4c. I think that may be a flawed assumption. Has AMD confirmed this info?
That would make sense, but I am afraid that Zen4 on APUs are just Zen4 with half L3.
Here is the info page, I suspect that Bergamo will say Zen4c
There will be no functional differences of course.I suspect that may be correct but I also suspect there will be no functional difference.
Why would AMD design a density / power optimised CCX twice when AMDs modus operandi is to copy paste stuff everywhere they can?
EDIT: there may be some slight differences between the Phoenix CCX and the one in Zen4c but I expect they are probably related to integrating them into the overall design rather than anything else. I expect the bulk of it to be the same because I see no reason why they would do the same work twice.
Because high density chips don’t scale in frequency. Also, laptop and cloud computing are AMD’s biggest potential market opportunities. It makes sense to optimize for each. AMD has stated a few different times that Zen4c is cloud only. The c literally stands for cloud.
AMD has done mobile specific SKUs for every generation, so this isn’t something new. They built a new chip for cloud providers because they will sell bucket loads of them.
Really? So the 7040 range does not exist then because they increased density vs the Zen4 CCD by 49% in a power limited design while maintaining upto 5.4Ghz boost clocks and 3Ghz GPU clocks. Or is 140M xtors / mm^2 not high density?
Seems perfectly fine frequency wise to me. So I ask again. If AMD already have this CCX design lying around why design another one for Zen4c? What is the business case to do so? Also what makes you think Zen4c is nothing more than the moniker AMD have given to the 16c CCD to differentiate it from the 8c CCD?
I agree that Zen4c is nothing new in terms of CCX design. Renoir was a Zen2c CCX, Cezanne was a Zen3c CCX. The difference is purely in taking that CCX design, putting 2 of them into a CCD and creating a product to sell them. Really 2 products because the 64c 4CCD Siena is going to be using Zen4c as well and that is probably why it exists. The top core count parts are no where near as popular as the lower core count ones so Zen4c was never just a high end play. It was a play to have a 64c Milan beating product in a cheaper package. That is where the volume and the business case for the Zen4c CCD will lie IMO.
EDIT to add. Now will Zen4c CCDs stay in cloud. Probably but with Zen 5 and the e-core spam from Intel I think AMD will go for a hybrid setup with a zen5 CCD and zen5c CCD. This gives them 24cores from 2 CCDs, maxes out single core clock speeds with the Zen5 CCD and allows for strong nT performance.
Those highlighted strings are just database entries. The values are entered by the author of this tool.Also
There's a difference between theorizing that a dense library is used and/or contributes, vs proclaiming that that must be what they're doing. In particular, I'm mentioning the constant transistor assumption as one to break.Yes because I am trying to get to a 'is this doable or is something else different' position, not this is the Zen4c transistor count and die size to +/- 1%.
Where did you see that Siena uses Zen 4c?In addition there is Siena which also uses Zen4c to make the package smaller.
The APU CCXs have been near identical to the desktop ones, being ultimately reused from server with similar power profiles to mobile. A throughput core with half the area is a different beast entirely.Well the APU CCXs have always been density and power optimised because they are usually built on the best node AMD are currently using and because they are designed for laptops where power efficiency and battery life are key metrics.
Was about to ask the same, but found out in the meantime that this comes from MLID - he sounded very certain, whatever that means.Where did you see that Siena uses Zen 4c?
I always thought that Siena was a SMB Server platform as well as Workstation or HEDT. So Zen4c with maybe only 3.x GHz would not make much sense for me. But maybe this is just confirmation bias from my side.
Means absolutely nothing is what it means. And I think you're right. No way is most of the workstation market going to deal with a 12 channel platform.but found out in the meantime that this comes from MLID - he sounded very certain, whatever that means
Where is this "49% better density" claim coming from?So the 7040 range does not exist then because they increased density vs the Zen4 CCD by 49% in a power limited design
That's the claim AMD themselves made. Probably talking about core + L2.Where is the evidence it has half the area?
Again, where are all of these numbers you keep throwing out coming from? No, Zen 4 in Phoenix is basically identical to Zen 4 elsewhere, but all current indications.A 50% density increase + half the L3 cache Vs a standard Zen 4 CCD gets you almost all of the way there and AMD have already designed that CCX for that node and library
