Zalman ZM-MFC2 Fan Controller
krotchy
Well, I saw the ZM-MFC2 at CES and figured I would wait a month to see if any info would come out, and so far all I have found is a review with no known release or price.
Hopefully it comes soon, but for now heres a review:
http://www.bcchardware.com/index.php?op...om_content&task=view&id=3518&Itemid=40
The standout features appear to be it has a Watt meter which can show you the power usage of your computer (Accurate around 5% according to review)
Also the fan control can be set by either voltage or fan RPM, and it also comes with 4 ultra thin temperature sensors for getting readings in various places in your case.
Tha Zalman rep guessed it would be in the 60-80 dollar range, and at that price I might consider it partially for the better look than my ZM-MFC1 and also because the Watt meter is a pretty interesting feature.
