ZALMAN VF900CU
avi85
988
My temps with my factory cooler were in the mid to upper 60's at load and it sounded like there was a vaccum cleaner in my case, but since I installed the vf900-cu it now loads at about 47-48 and is extremely quiet.
DasFox
4,668
46
If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed, and if you don't care about the newspaper you haven't ------> conformed
Now ponder that concept for awhile if you can grasp what that might mean. :)
Mark seemed to miss the idea of conformity with his statement, which is larger then being informed, or uninformed. :p
ALOHA
LOUISSSSS
8,770
54
yes the vf900 will work wonders compared to any stock gpu cooling. my x1900xt idles at 30c in a 70F room and load at 55
