- Jan 29, 2005
- 5,202
- 216
- 106
I just finished installing my brand new Zalman VF700-Alcu.
Everything went without a single problem. All steps were properly followed.
But there must be something wrong somewhere ...
First of all, please, take note that the fan speed was modified for the stock cooling. I use ATi Tool for that. But now, the IDLE temp is about 5ºC HIGHER, with the Zalman, than with the default cooling.
I still haven't verified for Load temps ... but just knowing that the IDLE temp is higher worries me. I don't want to fry it in 3DMark06.
I am pretty sure though, that the actual reason for that is because the Zalman's current fan speed must be low by default. The default cooling's IDLE temp was about the same without custom fan speeds in ATi Tool.
So, is there a way to control the speed of the Zalman AF700-Alcu fan ?
Because right now ATi Tool does not detect (or more exactly "can't control") the speed, since the 3-Pin power connector is NOT plugged in the GPU's slot (as requested by the user manual). I had to plug it in some sort of converter thingy with a bunch of wires, which in turn must be plugged in a 4-Pin connector (like those used to power-up Hard-Disks).
So, yeah, all was installed, it works great ... but I can't seem to be able to control the fan speeds.
EDIT: Oh and, the 3-Pin connector is plugged into the black slot (12V, Normal operation).
