ZALMAN fan controller
It's not exactly a handy feature. Either you leave it inside the case, in which case you won't see it, but changing fan speeds is going to be a pain; or somehow you place it outside of the case, but then it'll look ugly.
A front control panel is much easier and better looking. 🙂
By the way, I got mine delivered with my Zalman CNPS7000B-AlCu HSF for free. 🙂
Ah, that one. 😛 *shrugs* I'm not exactly familiar with front-end fan controllers, but after looking on Zalman's website, I'd say that's a nice one. I'd suggest waiting for the opinions of other people. 🙂
Yeah this looks to be a good one... I'm considering buying it to get rid of the crappy clicking noise that my ATI on-board fan controler makes. I hope I can figure out how to get a converter for that plug, it's the smaller type than a standard fan connector.
I just want to be able to tweak the fans to get the perfect balance of cooling and noise... I just don't know which is the best front-bay controller. There are alot!
Any experiences?
i like the nexus, forget which one it is, but four fan control and has adapters for 3 pin and 4 pin molex on each. some only have one or the other so check your fans
im still waiting for finals to get my new set up so i was jus reasarching everyhting im going to get but i will look at the plugs
