Zalman Experts...9700 LED Fan Question
djnsmith7
I've decided I'd like to disable the LED's on one of my 9700's & I don't know which wire(s) are specifically for the LED's. Can anyone tell me, with certainty, which colored wire(s) to cut to take care of this & not affect / disable anything else?
For those wondering, I contacted Zalman & they ran out of the non-LED 110mm fans some time back & deactivated the product. I couldn't locate an etailer who had them in stock.
Can you see the actual LED's? Follow the wires or simply cut/trim it at every LED. I guarantee as long as the cut wires don't short out on anything the fan will still work 100%.
-Jamie M.
