Zalman 9700nt VS i7 920 Box Cooler
PCTC2
3,892
33
Do you already own it? If not, it's not worth the money and you should pick up a better cooler such as the TRUE 1366RT.
If you do already own it, and you already have the 1366 bracket, why not? It's better, but there are a lot better choices for the money.
DarthRevan
232
zagood
4,102
The TRUE can be mounted that way as well, as can the xigmatech coolers, but why?
PCTC2
3,892
33
The TRUE-1366RT really is that much better at dissipating heat. The Zalman reaches it maximum heat dissipation rather quickly for such an expensive cooler.
And zagood is correct. You can mount it toward the top fan (as the Antec 900's side fan got in the way for toward the back mounting).
DarthRevan
232
So can i mont my CPU fan sending the air to the top of the case? (CM-690)
By looking at the TRUE and at 9700nt TRUE looks alot more simple, lol.
PCTC2
3,892
33
Yes. The mount allows you to have the tower horizontal and have a fan blowing upwards.
DarthRevan
232
And how can i get/do that?
But i can´t put my tower horizontal, i´ll keep it vertical, is there a way to change the CPU fan to make it blow upwards?
PCTC2
3,892
33
that's what I meant. You can mount it like the zalman in that picture. The mount allows the tower to have airflow front-back or bottom-top.
DarthRevan
232
How can I mount that way?
PS: The airflow would be better so the temperatures would be lower, if mounted like Zalman, right?
PCTC2
3,892
33
You rotate the bracket so the airflow points upwards. I think I've restated this point in the past 3 times. And I doubt the difference in mounting positions would cause more than a 1-2C difference in temperatures.
PCTC2
3,892
33
Test it out. You have a rear exhaust and a top exhaust. I doubt its going to affect you in any way. I answered before, it's at most going to affect you 1-2C. Not important in the grand scheme of things. Your processor running at 50C or 52C or 60 vs 62C is not going to affect you in any way.
