- Jul 21, 2010
- 20
- 0
- 0
Hey guys,
Just working on a new build and have a quick question for you. I opted to use a a Zalman 9700 LED for my CPU heatsink and was curious if I had to use the included FanMate 2?
The motherboard I'm using is a ASUS Sabertooth 990FX R2.0 and the BIOS look pretty thorough. I've read some other articles regarding inadequate fan speeds when using this heatsink and just wanted to make sure that if I plug this thing directly into the MB that it won't cause some issues.
The reason I mentioned the BIOS was because after reading the manual it looked like it has a pretty intense auto detection fan controller suite built-in and would be able to modify the fan speed on its own without the aid of the fanmate 2.
If anybody could point me in the right direction that would be great. Thanks!
