z560 volume knob static?
Dark54555
If it's not one thing, it's another. Anyhoo, just had to disassemble to put in a new dvd burner and put my Santa Cruz back. Now, when I turn the volume knob on my z560 control box, certain levels exhibit huge static. Any ideas?
Try turning the volume knob up to max and back down to nothing a couple dozen times. There may be some dust caught in there that's causing the issues.
The static thing with the volume dial is usually a sign of low-quality capacitors on the tweeter (can you say Klipsch Promedia?) but I've never heard of this with one-way designs.
If its only certain (I'm guessing high) levels, you could just max out master/WAVE volume on the Windows side to minimize volume changes on the Logitech (or just put the windows volume dial on the taskbar, or use your keyboard volume buttons instead).
you called it. blew it out with a little canned air, spun it a could times, fixed.
I figured that was it. Had to do that for mine, my gf's and a few friends who jumped on the z-560 bandwagon a couple years ago too 🙂
Strong longs - just did this 2-3 times while blowing really hard with my humid lung air! Maybe not ideal but it worked! (For now...)
