Z-560s + nForce 4.31 = soft rear spkrs low quality
lordfinesse
Yeah I have the Z-560 and they worked fine before with version 3.4 previous version but now with this version when I go through speaker wizard to set my speakers up properly I don't get the test sound from my rear left, rear right or subwoofer. Only the front 2 speakers so when I go through the process at the end it says I have 2 speakers, analog etc. So instead I just select 5.1 speakers from the list and my front two speakers and subwoofer work but the rear two speakers are echoy and very soft in volume. With the previous driver the rear satelites were even alittle louder then the front two, but now they are barely audible I have to put them to my ear to hear them and they are echoy, soft and bad sounding. Z-560s are actually 4.1 speakers but that isn't in the list to pick from it goes from 4 speakers to 5.1 nothing inbetween. I have my speakers set up right in the back of the subwoofer I don't have the rear and front speakers reversed or anything like that. I have them plugged into fine in the back of the mobo too so... Please help
-Barton AMD 2500 (3200 oc)
-Abit NF7-S Rev.2 bios 23; nForce 4.31
-512 MB OCZ 3200 (512x1)
-Barracuda 7200RPM 80GB 2MB
-Sapphire 9800 Pro 128MB CATA 4.3
lordfinesse
I don't get it... I gave a detailed description of my problem with driver versions, hardware etc. Its obviously some sort of driver problem but I was hoping there was a quick fix to it, a tweak if you will. Instead of having to use a older version of the audio nForce drivers.
Any help? or no dice
Zelmo3
772
Does your manual say you should be using 5.1 settings for your speakers? I would guess that the 4 speaker setting is what you want.
rbV5
12,632
In the NVmixer, go into the surround settings and try the different encoding options.( I'm using the Win64 nVmixer btw)
