Z-5500 Linking two sets with 1 Pod
sandmanza
Hi
My control pod on my logitech Z-5500 speakers went faulty and thus with logitechs warranty they send you a full replacement speaker set and you need to send the faulty pod back.
I have seen with the Z-680 and the Z-5500 people who decided that they would try out splitting the control pod to control both subs and thus end up with a 10 speaker 2 sub setup, apparently sounds great. However...
Voltage is supplied to the control pod via the sub, if you use a splitter and connect it then you are having double voltage sources, am I going to sit with 9v * 2 or 18v * 2 (18v is how much is normally supplied to it). Its basically parallel or series, blowing up a pod isnt on my priority list :D
The splitter is simply comprised of a male DB-15 connector to two female DB-15 connectors, without any crossover of cables inside.
I would greatly appreciate any feedback by anyone who has done this or knows how I can figure out the voltage problem.
Thanks in advance
BassBomb
8,390
Originally posted by: DisgruntledVirus
You could get splitters for the audio cable itself, instead of splitting it from the control pod.
this
why are you hookup up two?
sandmanza
That wouldnt work, its two subs 1 controller, the interface for the pod is a DB-15 connector, I need to control both subs with 1 pod. The power goes into the subs, thus that is the only option. Thus the only way would be via a cable I had made up.
http://www.bigpichost.com/file...ncw2ta6d0f25ugpa2g.jpg
but I am worried about the voltage as power is supplied to the pod from the sub for the pods decoding, LCD etc... to work
Edit: BassBomb, mainly for the concept and from the whole handful of cases I have heard it done apparently the result is quite awesome.
