SETUP
- 650i mobo with Scythe Ninja Plus Rev B, and nice copper NB/SB heatpipe cooling. Not currently using optional NB fan (its way loud)
- Antec P180B, upper HDD cage removed, 2 stock 120mm Tri-Cool case fans in upper chamber, 1 120mm Tri-Cool fan in lower chamber. Fans set to "Medium".
- Overclocked E6300 to 2.66gHz (380FSB), slight (.05v) NB voltage bump up to 1.35v (still well within safe values)
- OCZ Platinum Rev 2 DDR2 800RAM running 1:1 @380(2T = 760mHz), 2.0v, 4-4-4-15 (advertised timings)
TEMPS IDLE
CoreTemp - 38-40c
TAT - 36-38c
Speedfan - 21-23c
TEMPS FULL ORTHOS LOAD
CoreTemp - 58-60c (hits 60 on tests 4 & 8)
TAT - 56-58c
Speedfan - 36-38
Notes - I sure wish Speedfan were correct:laugh:. RAM voltage set to "Auto" - I certainly think I can drop that to 1.9, given that this RAM is advertised for 1.9-2.1 range. So I guess that could help a little? I'm a little disappointed in the Ninja's performance, but perhaps it should be reseated. Makes me wonder if I put the fan on properly, ie, blowing the right direction:roll:. First build. First OC.
TEMPS IDLE
CoreTemp - 38-40c
TAT - 36-38c
Speedfan - 21-23c
TAT - 56-58c
Speedfan - 36-38
