Your thoughts on my case/system
MeSh1
104
Howdy all my next system is going to consist of:
amd fx-53
msi k8n neo2 platinum
x800xt PE
dual sata raptor drives
Havent decided on a heat sink/fan yet or the memory im going to be getting. The case im going to buy is a CM STACKER case adn i was wondering what you guys though about my choice in case and also if you have any suggestions for a hs/f. I do want to overclock and im going to get the case with the cross flow fan and all of the 4 in 3 device modules which each include a 120mm fan. :D. any input would be appreciated.
Tiamat
14,068
If it fits, Thermalright XP-120 and Panaflo 120mm M, or Acoustifan 120mm.
If not, Thermalright SLK 948U and Panaflo 92mm M, or Vantec Tornado 92mm (depending on your desire for noise.)
Cm Stacker is like 50 lbs, but should be sufficient. Ive read only good things about it, except that there is some funky business with the front bezels - hard to remove or something...
Make sure you get an Antec TruePower 480 or better, or Enermax Noisetaker 480 or better, or other well known PSU.
tonyou
508
If you think the current Stacker case is heavy then you should hurry and get one before it gets even heavier. Due to quite a few problems with aluminum top panels getting dimples from the steel hard drive cage during shipping, they will begin switching to steel top panels on their next production run. But what difference does 1-2 additional pounds make when the case is that heavy already? ;)
MeSh1
104
Thanks for the recommendations much appreciated. The case is heavy, but I just want a case that'll give me optimal cooling. I dont plan on taking it anywhere so thats why im going to go with this case. If i decide to move it it'll move nearby if i decide to rearrange my furniture and stuff. Anyways, i cant wait untill this systme is completed. Only problme is my mobo isnt widely available :(
