Your system at risk.... Antivirus not installed
knightrider
115
hi there....i have winXP
i have an antivirus installed in my system which is doing good .., but
from the past two days, the windows securtiy allert displays a message..
YOUR SYSTEM AT RISK.... ANTIVIRUS NOT INSTALLED..
why does this happen. Is my antivirus not working or is it the problem with the system...
I tried re-installing the antivirus but for no use..
Please help..
thanks in advance:(
Sunner
Maybe it simply doesn't recognize it?
It didn't recognize AVG 6 either, when I upgraded to AVG 7 it didn't complain.
Of course, about the first thing I do is turn of that annoying security center, so in the long run, it wouldn't matter anyway :)
knightrider
115
No it did recognize earlier..
I have been using from the past 3-4 months...
This problem araised 2 days back...humm
MrChad
13,507
Originally posted by: malak
Just turn off the security center. It doesn't help as far as I know.
It's not necessary to disable security center completely. Open it up and click on the Recommendations button under Virus Protection. Check the box that says "I have an antivirus program that I'll monitor myself". The antivirus section will change to a yellow "Not Monitored" status, and your alerts should go away. Make sure you keep your antivirus up-to-date!
imported_Zeke
956
:thumbsup:
InlineFive
9,599
:thumbsup:
I agree, Security Center is very useful for making your system is up to snuff on it's updates. I like to leave it enabled.
