[ You Tube ] AMD's Top Secret Mission
VulgarDisplay
6,188
So it is possible. But why are they using two pumps? That's what they are showing, correct? Isn't one enough? Not like you're going to get any extra volume of water pumped as the same amount of water has to pass through the second pump as the first. Or is only one of them a pump?
There were pictures of it exposed on chiphell but they are gone now. I would imagine that the two pumps are for redundancy. If one fails the loop will still work.
antihelten
1,764
274
I don't know but I would guess they are using two pumps, mainly because they are using generic asetek stuff, and simply using the normal intregrated heatsink/pumps is more straight forward. I suppose using two pumps could also theoretically be less noisy since the pumps don't have to work as hard.
Keysplayr
21,209
50
Is it a common thing to have two pumps in any water cooled system? I mean, one that has only one radiator?
cytg111
23,935
13,427
it felt a tad too amateurish - not something that compels me to fork over 1k+ for a card and drivers.
I was sure he was gonna stab himself in the eye trying to get those glasses on with one hand..
Grooveriding
9,110
1,260
Where do you see that it mentions about two pumps?
I see two blocks because there are two chips but I wonder if they put another pump in the other block.
I presume there is only one though.
I bet this cooler can be easily modifiable. Anyway, if I was to buy this card, I would slap a waterblock right away for 150$ and call it a day.
Pretty much. This card would be insane on a custom loop. My guess on temperatures, considering the amount of rad this comes with, is that they will be similar to a good aftermarket air cooler. Maybe 60-70C. That is a lot of heat for 120mm of rad to handle.
Temps will be great and overclock will be excellent. But overclocking involving additional voltage will likely cause really high temps. But put this thing under a custom block and it will be insane.
TreVader
2,057
Why would you need a custom block? That would seem like a waste of money vs just adding a second Rad.
TreVader
2,057
The second pump is for redundancy. They both run in series but it only needs one to be fully operational.
Keysplayr
21,209
50
rgallant
1,361
11
I have 2
you can run them at low speeds or both med. and get lots of flow which could help the 1 rad , but with 1 rad surely temps of the fluid will hit it's max. temps and pressure. I'd want 6-9 times that rad space.
2is
4,281
131
The video was pure [redacted]. Silver lining is that it only has 8k views. AMD should take it down ASAP.
Profanity isn't allowed in the technical forums.
-- stahlhart
Keysplayr
21,209
50
I think if one pump fails, it would therefore obstruct waterflow for the other pump. I don't see how water would pass freely across the impellers of a dead pump.
DigDog
13,726
2,253
you'll need one of these
TreVader
2,057
I think you don't know how pumps work.
When one breaks it doesn't interrupt water flow, but it will lower the flow head. Pumps in parallel increase flow, pumps in series increase head. But nice try!
Keysplayr
21,209
50
What do you mean "Nice Try" ? What am I trying to do but understand the setup?
And what difference does it make whether the waterflow, or the "pump head" is lowered? Won't there STILL be less water flowing regardless? Sheesh.
P.S. and if you answer no, I'd like you to offer some proof of this please. I'm ready.
What you gave me up above was sounding like a google search answer.
VulgarDisplay
6,188
Martin's Liquid lab is like the bible of water cooling. Their testing shows that you lose maybe 2% pumping performance if one pump quits in a loop that is in series.
http://martinsliquidlab.org/2011/04/26/pump-setup-series-vs-parallel/2/
Ok, so how does series handle the loss of one pump you might ask? Obviously you lose the power of the additional pump, but I wanted to see what happens to the remaining pump. Many forum members have suggested that a pump is highly restrictive when stopped and imply that performance in the remaining pump is degraded heavily…is it true?
No.
While you do lose the power of the second pump that was turned off, the restriction of the still pump is is very small. On average you will only see about a 2% loss in pumping power vs. a single pump setup. Series setups retain nearly full pumping power of single pump setup and therefore pass the redundancy check with flying colors. Not only do you get adequate redundancy, you pretty much get full single pump setup power. No problem…
KingFatty
3,034
Well now I'm pumped up about all this.
My brother hooked up his closed loop to a heat exchanger with a separate closed loop to his outdoor pool. GPU-water heater for the pool.
96Firebird
5,714
316
Is that for a seized pump, or a pump that is just turned off and is free to rotate? Centrifugal pumps do have free space outside of the vanes, but I can't imagine it is only a 2% loss for a seized pump.
Keysplayr
21,209
50
Logical thinking would tend to agree with you, but maybe they're designed to let water pass through when they fail.
KingFatty
3,034
The water pumps I've seen have the ability pass a flow even when the impeller is stopped, because of the related and flipside benefit: if you block the inlet or outlet tubes, the impeller may still spin and move the water around in the pump housing, without breaking. So I think the two aspects are related when it comes to water pumps. You can stop the motor and water is still able to flow freely over the impeller, or you can clog/block the flow and the impeller is still able to freely spin without overloading. I think it's different than other types of fluid pumps, like a gear-based oil pump where there isn't that ability to free-spin or free-flow when things are messed up.
