CallMeJoe
- Jul 30, 2004
- 6,938
- 5
- 81
Originally posted by: PurdueRy
LOL
don't confuse him!
I guess we need a good "sarcasm" smiley.
LOL
don't confuse him!
LOL
don't confuse him!
I guess we need a good "sarcasm" smiley.![]()
Originally posted by: Squisher
I can't believe this thread lives!!!
Let's pretend the plane is flying at 200mph. I hang out of the plane and attach a treadmill under its wheels and cause the wheels to spin at 200mph.
WILL THE PLANE FALL OUT OF THE SKY??????????
Originally posted by: Zenmervolt
The conveyor belt cannot ever match the speed at which the wheels rotate. It's simply not physically possible given that an airplane produces thrust by virtue of Newton's Third Law relative to the air, not to the ground. To borrow the explanation from The Straight Dope:
"...some versions put matters this way: "The conveyer belt is designed to exactly match the speed of the wheels at any given time, moving in the opposite direction of rotation." This language leads to a paradox: If the plane moves forward at 5 MPH, then its wheels will do likewise, and the treadmill will go 5 MPH backward. But if the treadmill is going 5 MPH backward, then the wheels are really turning 10 MPH forward. But if the wheels are going 10 MPH forward . . . Soon the foolish have persuaded themselves that the treadmill must operate at infinite speed. Nonsense. The question thus stated asks the impossible -- simply put, that A = A + 5 -- and so cannot be framed in this way."
ZV
ZV
I guess I am one of the "foolish" who have persuaded themselves that the treadmill can defeat the plane.
I think you're neglecting the effects of rolling resistance when combined with an infinite speed of the belt. No matter how efficient your wheel bearings are, there is always some drag. With enough speed on the conveyor, the backwards drag from the wheels' rolling resistance will overcome the thrust from the jet's engines.
That's a lot of resistance!!!
The treadmill only travels as fast as the plane is moving...its not going to be enough to keep the plane from taking off
If you mean that the belt can only go as fast as the plane is moving, but in the opposite direction, then I totally agree with you- they wouldn't stop the plane. Instead of the tires spinning at 170 mph which is a normal takeoff speed, they'd be spinning at 340 mph.
I took it as asking if you can prevent the plane from taking off by spinning the belt faster and faster. In that case you could.
Theoretically...you have to realize you would also have to find motors that could spin a treadmill as fast as was needed....
I know, I know... it does get ridiculous pretty fast. Let's just say that the treadmill is powered by Duke Nukem Forever after drinking some cold fusion energy drink.
THAT WILL NEVER TAKE OFF :evil:
Originally posted by: OdiN
This thread is still going?
I say it doesn't take off.
Why?
Because the OP said that there is no airflow over the wing. That may break the law of physics, but as it is this is just a hypothetical question anyway.
No airflow = no takeoff
Whatever or how there is no airflow I guess doesn't matter in this case.
Somone should have just posted that and ended this useless piece of crap thread.
Originally posted by: 1prophet
If it's a Harrier would it take off?![]()
Why?
reading comprehension is not a strong suit of yours eh?![]()
"but the source of thrust is at the back of the plane so it never provides airflow over the wing. " - AKA the engines do not blow air over the wings
Why?
SHUTUP....this thread needs to die!
Originally posted by: D1gger
The wheels are not driving the plane forward, the engines are, so the plane moves forward until the air passing over the wings gives it enough lift to take off. The wheels spinning on the conveyor belt have absolutely nothing to do with the physics of a plane flying.
LOL
don't confuse him!
I think you're neglecting the effects of rolling resistance (which increases with wheel speed) when coupled with the possibility of an infinite amount of wheel speed (imparted by the belt). No matter how efficient your wheel bearings are, there is always some drag. With enough speed on the conveyor, the backwards drag from the wheels' rolling resistance will overcome the thrust from the jet's engines.
That's what you get when you're given a hypothetical situation where one object has no boundaries while the other one does. It's sort of like asking if ants could tow an aircraft carrier if you had unlimited ants. Sure they could. Ants can pull some non-zero amount of weight, and when you combine that with no limit to the amount of ants, they can't be stopped.
In our situation above we have a very minor influence like rolling resistance fighting against immensely powerful jet engines. But the person who posed the question made the engines limited in power, while they gave the belt no limitations whatsoever. So it's easy to see that given that scenario, you can easily make a minor factor like rolling resistance overcome the power of the engines by dragging the belt speed up towards infinity.
Originally posted by: Penththe wheels really have nothing to do with the propulsion or velocity of an airplane.
The belt compensates for the rotation of the wheels in reverse, as in the belt moves in reverse exactly as fast as the wheels move forward.
:smackshead:Originally posted by: StrangerGuy
The plane doesn't move forward relative to the air around it. So it cannot take off.
Man that was soooooo hard.
