You guys help me out on my stereo system..
LongCoolMother
5,675
ive got a Philips FWP900 shelf system in my room. i keep them all aligned up in a row next to each other. Problem is, i have pro logic on it and stuff. when i set it on full surround mode (uses all the speakers, all 3 sattelites, and other speakers) the sounds gets all....weird. it sounds almost like a mono sound, or maybe a sound with a very low bitrate...when i set it on phanton, (uses 2 sattelites and everything else, just doesnt use the center sattelite). it sounds very good. crisp sound, and even kind of echoey...hmmm, is it supposed to sound all mono like with it on surround mode? or is it just my positioning?
http://www.consumer.philips.com/global/b2c/ce/catalog/product.jhtml?divId=0&groupId=AUDIO&catId=HOMETHEATERSYS&subCatId=HOMETHEATERSHELFSYS&productId=FWP900_17
theres a link to the system i have in my room..
spidey07
65,469
Of the utmost importance......
what is the source of your audio? cableTV, satelite, CD, DVD, etc.
Most likely it is the source you are listening to. Use PLII only when you are listening to recording encoded with Dolby ProLogic. (vhs, very few cable/dss shows)
