Yo, help me out peeps.
Riddler
273
there's a couple of sites on the net that check compatiblity, but you probably already know what the problem is, just don't know how to fix it for netscape. what are you using, frontpage? i have to use that at work, and i also have problems with netscape, and haven't figured out how to fix it, without diving into the html.
shawnmos
Banned
Dec 11, 2000
2,136
Well I don't have the slightist clues as to why the tables aren't displaying properly. I know why the borders aren't working though. It seems netscape doesn't understand the "bordercolor=" code. I don't know how to get it to work though. :( For the most part I used Frontpage but i did some by hand too.
