Let me begin w/ saying that, I've Xperienced ZERO problem's w/ my PC until I upgraded from my old ATI 8500 to an eVGA 6800GT... somehow, the 6800 & my PC R NOT getting along :'(
I'll get a BSOD @ the desktop w/ no apps running, in Doom 3, browsing the internet, whatever. It's very intermittent cause sometimes I'll get it 3x in a row in an hour span, sometimes I won't C it 4 a good coup days. [playing a game (gpu intensive), @ the desktop w/ no apps running (just windows), or even installing WinXP itself (nothing running!)... I AM GETTING BSOD's.] I've had 2 do my fresh installs w/ the ATI 8500 & swapping in the 6800 after complete, or I'll get a BSOD and not even complete WinXP setup (w/ the 6800). I've even gotten BSOD's @ the desktop w/ no apps running just after a cold start.
The BSOD should B an obvious answer, but I'm getting 1x of 2x BSOD's. The most popular, it C'ms ringing in @ ~7 out of 10 BSOD's, is the infamous "Driver IRQL not Less or Equal." As I'm sure U're aware, the BSOD flashes pretty quickly B4 rebooting, but I have yet 2 C a driver associated or referenced in this BSOD. This in itself could point 2 just about anything in a PC, hardware & software.
The 2nd BSOD I'm shown is an entirely diff BSOD than I've ever C'n B4 in all my years of working on PC's. It's a VERY generalized error message that takes the entire screen & takes fast reading B4 the PC automatically reboots! It basically says that a general system problem has occurred & Windows has been stopped 2 prevent damage 2 the system... blah, usual stuff here. It goes on 2 say 2 check your system's configuration, settings, and look 4 general hardware changes. It specifically says @ the very end 2 try changing Video Cards which I found 2 B an interesting statement, the only suggestion of actually changing your hardware. I can't say I've ever C'n this kind of BSOD B4 as it really doesn't give the tech any direction or information on possible causes. I've pointlessly tried searching the Internet 4 a complete writeup of what it reads & an Xplanation.
4 the most part, BSOD's entail Windows saying that whatever.dll has caused an error... whatever device that library controls should B the cause of the problem. Unfortunately, I'm struggling w/ these very non-informative BSOD's.
It shouldn't B a cooling prob, even though eVGA's stock cooling does thoroughly suck... my case does make up 4 the difference. I've monitored the temps under both idle & load conditions 4 Xtended periods w/ no probs, w/ the 6800 rarely reaching the highest of 65'C under full load. Keep in mind I've tried 3x different 6800's (See config & failed attempts below). I have been running the entire time of troubleshooting w/ all covers off.
Here's my configuration:
AMD Athlon XP 3000+/2.167GHz (333MHz FSB)
Asus A7V333-RAID Rev 2.0 (BIOS 1018.001) w/ confirmed working 1/5 Divider (333MHz FSB)
1GB (2x512MB) OCZ PC2700/333MHz DDR
eVGA 6800GT (BIOS 5.40.02.15.01) running @ STOCK running AGP 4x (8x not provided by mobo)
Creative Labs SB Audigy 2 ZS (7.29.04)
Linksys Gigabit EG1032 NIC
160GB RAID 0 Striped (2x 80GB PATA133 Maxtor)
Pioneer DVR-108, Iomega Zip 250 (ATAPI), Floppy
Enermax EG651 550Watt (Peak 650Watt) Power Supply (Rated for 36a on 12v Rail)
APC 1000va 600 Watt UPS (Reporting ~280Watts usage w/ EVERYTHING including monitor, etc.)
WinXP Pro SP2 w/ DirectX 9c, Via 4-in-1 4.51 Hyperion, 61.77 nForceWare
Needless 2 say, all unneccessary cards & drives R removed & unplugged 4 testing purposes.
This is a tried & true, tested system I've been using 4 the last ~1.5 years. It is heavily mod'd & CPU runs a constant ~40'C w/ air cooling under full load. I've pointed out that I've UNDERCLOCKED my system 4 testing purposes. The 6800GT itself runs @ 50'C idle & 65'C under full load.
Failed attempts at fixing (no particular order):
eVGA 6800GT (NOT overclocked)
Disabled USB (had shared IRQ 16 w/ eVGA 6800GT)
Set Fail-Safe BIOS Settings as recommended by eVGA
Ran Memtest86, DocMemory, and Microsoft's Memory Diagnostic (all okay)
Removed one stick of memory and alternated other in 3x available slots
Front Side Bus (FSB) UNDERCLOCKED to 133MHzx2 = 266MHzFSB
Tried 2x different eVGA 6800GT's as well as a nVidia Reference/Eng-Sample 6800 Ultra
Tried a spare A7V333-Raid Rev 1.2 Motherboard
Uninstalled (or never installed) Norton AntiVirus 2004 Pro
I'm generally a passive browser of Internet forums in general, and only post whenever I get really emotional or have something I feel is unique or intuitive 2 contribute, and D*MN IT I'M EMOTIONAL RIGHT NOW (lol, j/k, ok... well, mayB not). But I could really use some help on this 1.
I think I've searched the entire Internet over a coup times in trying 2 get some leads in fixing this prob, but I just can't C'm 2 get it gone. I love AnandTech, I think the site is great & visit daily. I'd like 2 say I remember some1 here in the forums saying that they R really good @ understanding minidumps... if any1 has the slightest clue, I've zipped & uploaded my minidumps 2 here:
http://www.EdgeProductions.com/minidumps.zip
I would B 4ever grateful if some1 could help me out or point me in the right direction!!!!
P.S.
For those interested in my benchmarks of the 6800 GT & Ultra as AGP 4x (as opposed 2 AGP 8x) on an AthlonXP 3000+/2.167GHz, U can find mine here (interesting nonetheless)... http://www.mhclan.com/avatar/6...ormance_Comparison.htm
Oh yeah, 1x last thing... 2x things actually I'm in the process of doing. These R, unfortunately, 2x of the LAST things I can possibly think of.
The entire line of Asus' A7V motherboards have notoriously BURNING HOT System Clock Generators as I've researched across the Internet. Specifically, my Asus A7V333-Raid Rev 2.0 ICS 94228 System Clock Generator will burn your finger if U hold it there 4 too long. I never noticed this B4 but have confirmed that this C'ms 2 B by design (Asus B'ing greedy?). Anyways, I'm in the process of putting a small chipset heatsink & fan on it 2 hopefully add some stability.
A picture of some1else's passive cooling:
http://darkforce.dyndns.org/pics/clockhs.jpg
The forum I found this gem of advice:
[http://forums.pcper.com/showth...4&page=4&pp=15]http://forums.pcper.com/showthread.php?t=155944&page=4&pp=15[/L]
The 2nd and last thing I can think of is 2 get the nvSilencer 5 for the 6800 & hope somehow dropping the temperature another 10'C will somehow add more stability.
I would B PROFOUNDLY GRATEFUL were some1 2 provide me a lead, revelation, or make sense of the MiniDumps!
I appologize 4 the novel, but wanted 2 avoid repetition... & Thanx Every1!
- J
P.S.
- J
