I recently replaced (for the third time) the NB cooler on my IC7-G mobo. When mounting the new cooler (Thermaltake Extreme Spirit II), one of the mounting loops broke off the board. (Poorly designed mounting method for this cooler makes it way too easy to overtighten the hooks.) Fortunately, the board had four loops, so I was able to use the other pair to mount the cooler.
Lately, my rig has been getting slow while gaming, or not correctly burning a DVD (DL coasters are expensive, too!), so I peeked into my case and discovered that the OTHER loop my new NB cooler was connected to had broken away, and the cooler is more or less just dangling off the motherboard. Worse, it is the loop on the same side as the one that had broken off while mounting it in the first place, which means I have no loops left for securing a cooler on that side of the NB.
So, am I basically stuck buying a new motherboard (and I'm sure it won't be easy to find an AGP board, nowadays, that will fit my existing P4C CPU and AGP videocard), or is there a decent stick-on NB cooler I can use? Or, can I use a good piece of thermal tape for this cooler reliably, without it being fully mounted to the board's loops? Since my case stands upright (as most do), I'm afraid the cooler might be too heavy for thermal tape.
Suggestions? Money is tight right now, so I'd rather not build a whole new rig, if I can avoid it.
