1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming 99% of the time
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I would like to have it around $900-$1250
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
EVGA video card is the only thing I will not change
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Mouse, keyboard, monitor
6. IF YOU have searched and/or read similar threads.
Yes
7. IF YOU plan on overclocking or run the system at default speeds.
I dont plan to overclock, but Im open minded about it.
After searching and reading the boards for a month or so I have finally decided to try my hand at building my own PC instead of hitting up Dell for my gaming needs. I looked through quite a few builds and pick out some parts that I thought would fit my needs. Listed below is what I think I should go for. If any of you know of any better suggestions that would reduce the price, but not the performance please let me know.
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard - Retail
http://www.newegg.com/product/...x?item=N82E16813128059
Intel Core 2 Duo E8400 - If I can even get ahold of one
http://www.newegg.com/product/...x?item=N82E16819115037
OCZ StealthXStream OCZ500SXS ATX12V / EPS12V 500W Power Supply - Retail
http://www.newegg.com/product/...x?item=N82E16817341012
2 X - For a total of 4gb - Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT12864AA804 - Retail
http://www.newegg.com/product/...x?item=N82E16820146565
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/product/...x?item=N82E16811129021
EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready
http://www.newegg.com/product/...x?item=N82E16814130325
Western Digital Caviar SE WD5000AAJS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/product/...x?item=N82E16822136178
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM
http://www.newegg.com/product/...x?item=N82E16827151153
With how the prices of video cards are would it benefit me any to move up to the 640mb version of the GTS or even the GTX? Is that just a waste of money?
Also Im a little unsure of what version of Vista I need. I do know I want the 64 bit version. Is it possible to purchase 1 copy of the 64 bit version that I can load onto multiple computers without any issues?
Thank you all very much for your feedback.
USA
Yes
