TheInternal
I'm in the process of making a new system to replace my ancient socket 939 Athlon 64 x2 system. I've been putting a crap load of time into researching components, but am still second guessing myself in a few areas, particularly the video card, memory, and the motherboard.
The price has rapidly escalated beyond what I was initially hoping, but I'd really like to get some top notch components that will run quietly and be stable for a long period of time.
I plan on using the system for gaming, school work, and occasional graphics design work. I also make music, so I want the onboard sound to not suck. I was hoping to stay closer to $1000 before monitor purchase, but the price has rapidly come closer to $1750 without monitor.
I'll be buying my parts in the USA. I'm generally brand neutral, though sometimes a bit biased towards brands I've had previously good experiences with. I want a system that's powerful, damn-near silent, and stable. Already purchased parts are noted.
I'll likely run the system at default speeds, though a mild overclock isn't outside the realm of possibility. Initially, I'll be running the system at 1920x1200 with a 24” monitor via DVI connection and, graphics card allowing, a secondary little 1024x768 display via d-sub. I hope to upgrade to a 27”-30” 2560x1600 monitor flanked by two 24” monitors at 1920x1200 (or at least 1080p) by the end of the year.
I plan on beginning component purchasing as early as tomorrow.
Current components I'm looking at:
CPU
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000
http://www.newegg.com/Product/Produc...82E16819116504
CPU Heatsink
Zalman CNPS 10x Performa (Already purchased)
http://www.newegg.com/Product/Produc...82E16835118059
Motherboard
Current contenders-
ASUS P8Z77-V Pro (the board I'm currently leaning towards; I've had very positive experiences with ASUS motherboards, found lots of very positive reviews from numerous reputable sites, but find the archaic PCI ports silly)
http://www.newegg.com/Product/Produc...0P8Z77-V%20Pro
MSI Z77A-GD65 (yay for no archaic PCI ports, being able to do three-way SLI at x8x4x4 speeds though I doubt I'd ever do more than 2 card SLI / crossfire, am intrigued by the THX certification, but a little nervous about MSI's board based on some previous motherboard experiences)
http://www.newegg.com/Product/Produc...82E16813130643
RAM
The big question mark. I've concluded I should get at least 1600 speed based on reading numerous articles, but am not sure if there's enough of a speed difference to justify higher cost memory or how much of an impact on stability / lifespan of the system an overclock would be for something like 1866 speed. I also don't know the minimal CAS latency I should aim for.
I'd like the RAM to match the "looks" of the motherboard. Preferably black heat sinks, or possibly blue. I'm partial to Crucial due to previous dealings, but am open to other brands. I'd prefer to get a 2 x 8 GB kit, but am open to 4 x 4 GB kits if there's a significant performance difference or the cost / performance ratio is better.
Video Card
The other big point of uncertainty. I currently run a Geforce GTX 550 Ti in my main system and would like to get something more powerful.
I'm considering either the Radeon HD 7850 at approximately $250, or the New Geforce GTX 670 2GB at the rather pricey $400. I'm having trouble figuring out which is the better bang for the buck, or who makes the best card that runs quietly.
I'm currently eyeballing the ASUS GTX670-DC2T-2GD5 GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card (it's marketed as being quiet, though I've no idea how true this is)
http://www.newegg.com/Product/Produc...82E16814121638
Storage
boot drive / programs - Mushkin Enhanced Chronos Deluxe MKNSSDCR240GB-DX 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Produc...82E16820226226
media storage / documents -
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive (already purchased)
http://www.newegg.com/Product/Produc...82E16822136284
LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner with 3D Playback iHBS212-08 LightScribe Support (blu ray with 3d and lightscribe support)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106348
PSU
SeaSonic Platinum-1000 1000W ATX12V / EPS12V 80 PLUS PLATINUM Certified Full Modular Power Supply (powerful, quiet, modular, good warrantee)
http://www.newegg.com/Product/Produc...82E16817151105
Case
Antec P280 Black ATX Mid Tower Computer Case (I've loved my Antec p180b, and heard this is a worthy successor for near silent computing.)
http://www.newegg.com/Product/Produc...82E16811129179
Additional Cooling
Noctua NF-P12 Fan 3-Pack
http://www.amazon.com/Noctua-NF-P12-...8367307&sr=1-6
Once again, I'm looking for something powerful, stable, and QUIET. Suggestions on all parts welcome, but suggestions on memory (with reasons why) and video card (best bang for the buck and lack of noise) are the most needed at the moment.
Thanks!
CPU
CPU Heatsink
Motherboard
Current contenders-
RAM
Video Card
Storage
PSU
Case
Additional Cooling
Thanks!
