Ok, so I was having problems with my new P4 system. I thought it was the PS so I used my old k7 mobo with the new power supply to see if the system booted up. It didn't, once I pressed the power switch the fans would spin for a second then stop, this was the same problem plagueing my new P4 system, so I concluded there was probably something wrong with the PS.
Ok, so I go back to switching everything back to my other case. Hook everything up, etc. When I turn on the power the fans, cpu, and hd start up and spin like normal but no video signal and my system no longer posts, it doesn't beep or anything. It is also worthy to note that the ethernet card when its plugged in, the lights light up. So in essence, everything powers up but no post and video signal. I tried powering up with just the vidcard, ram and cpu and still nothing. I also let the system run for a few minutes and see if it booted up to the OS and then pinged its respective IP, but it didn't work. So it seems that even if there is no video signal the system isn't booting up to the OS. Any suggestions/help are highly appreciated. Thanks!
-Damian
-Damian
