ive got 4 gb of ocz platinum pc2 6400 4-4-4-15
If I stick all 4 sticks in its bsod time.
Does anyone know how much better (if at all) the crosshair is than the m2n32-sli deluxe? I got it this afternoon, and can return it to newegg still.
Thanks
well figured out my problem. http://support.microsoft.com/kb/929777
installed vista w/ 2gb then installed this then stuck it all back in and presto! Im posting with 4gb
in case anyone has the same problem.....
