Hi guys - sorry it's kinda long but please bear with me.
I am 5'10" weigh about 145lbs at the moment. I started working out 3 months ago off an on, and I go to the gym about 3 times a week.
I used to be at 160lb but after discovering that I have high cholesterol I lost a lot of weight afterwards down to 140lbs, cutting down on meats(especially red) and fatty foods.
My goal is to get to back up closer to 165lbs, but with as much lean weight as possible. I do about only 10 mins of cardio when I do go work out. At 145lbs, I believe I am for the most part lean, I am somewhat cut and have a 6 pack showing but could stand for a lot more definition.
My problem is that I know I also need to eat more but when I do eat, I feell my gut building and my 6 pack starts to disappear. I want to bulk up but not lose definition and need advice on how to do this properly.
Someone suggested that I take some MRPs in between my meals - they are low fat and packed with protein so when I lift, it would help as well. Anyone recommend some MRPs or if that is even the way to go about it?
I also know I need to do cardio since that is the one way to help lower my cholesterol and burn fat. But I keep hearing people say don't do cardio since that eats into muscle growth.
I just want to get on the right track - I work out my pects, tris and abs workout day one, bis, traps, lats, abs workout day two, and one the 3rd, legs, shoulders, delts.
Also, is it true that when you lift, you need to vary the position of the arms spacing? Closer for inner chest development, and wider for outer?
I would appreciate some advice from some workout gurus here on AT. Thanks in advance!!
