Yet Another Turn Signal Thread
I never thought you could say that, but there was one posted here a day or so ago.
So here is the problem, maybe one of you auto gurus can put me in the right direction.
My vehicle was recently shipped overseas for me, so I'm not sure that I can get warranty work done on it by Chrysler here in Germany. I am checking that out though.
Recently my left brake light has been going out periodically. The tail light portion of it works fine, just the brake light goes out. It is intermittent though... At first, I thought it was just a short somewhere, but then the electrical problems get wierd.
My right turn signal is also having intermittent problem, but not at the same time as the break light. (as far as I can tell). Occasionally, when I turn on the right turn signal, my hazzard lights come on instead. It is only with the right turn signal. I have checked all the bulbs on the truck and no matter what I do, the problem persists. But it gets better... the turn signal thing only happens after the truck has been run for a bit. Sometimes it takes a few minutes to start happening. Some times I can drive it most of the day. Once it starts however, it continues to act up every time the signal is used until the truck is allowed to sit for a period of time again.
As I said... I will try to see if Chrysler in Germany will do warranty work on the vehicle, but I thought maybe it is just something stupid, and I could avoid the hassle.
Any help?
Any help?
