Yate loons and fan controller...
JDawg1536
Im looking to get some fans and a fan controller. Where do you reccomend to order from? Also what fan controller is best? Im looking for something that can cut off power completely. I cant remember the name, but there was one that had some led lights on the front and a good wattage capacity.
Yeah the Sunbeam, thats it. Its out of stock in black from that site and many others. Anyone know where I can get a black one?
Wait a minute!
That controller goes all the way to 0V!
That seems like an excellent thing for an experiment but not very safe for everyday use. I mean what if someone else uses your PC and plays with the controls. They could completely turn off some critical fans! You wouldn't want that, would you?
Originally posted by: Navid
Wait a minute!
Im in the military and live in a 3x5 cell. Im the only one who ever uses it. Thanks for the help guys!
I have an Antec 180 case on the way, and they would be used for HD cooling, PSU cooling, both exhaust fans, and for a Thermalright 120...... I think I might get them from jabtech. The fans are 3.70 each, and the silver controller is only $11. Think that would look tacky on a black case or would it be ok? I dont care about looks a whole lot anyway.
The Sunbeam Rheobus doesn't come with fan extension cables like most others do so you'll want to get some fan extensions when you place your order. Might as well get 4 extensions so you'll have one for each channel - shoould be $1.00 or less each.
.bh.
