- May 20, 2004
- 150
- 0
- 71
Hello all,
It has been 6 years since my last system build, and I'm completely out of the loop.
I'm looking to build a new system and would appreciate some help. Every time I build a new system it seems to get a little bit more overwhelming.
1. What YOUR PC will be used for. Gaming, general computer use.
2. $1000 budget
3. USA build. I usually purchase everything from newegg. Amazon will also work.
5. No brand preference
6. I have a ATX case. Reusing keyboard/monitor/mouse/cd drive
7. NO overclocking. I want to put this thing together and not think about it for 5 years. Stability is key.
8. 1920x1080. I would like the flexibility to get a new monitor with a higher resolution sometime in the future.
9. WHEN do you plan to build it?
"soon"
10. Need windows 10
I do want 16 gigs of ram. Everything else I'm pretty flexible on.
Thanks!
2. $1000 budget
"soon"
10. Need windows 10
Thanks!
