draw right angle triangle with two points plus the right angle
chop the shorter sides in half (horizontal and vertical)
draw lines from the halfway points to the long side (they should meet at the halfway point yah?)
use a little algebra to show that the two halves of the long side are the same length
good luck I haven't done that in a while, this is just my best guess
