YAMT: A quick math problem
VTboy
Banned
y"' - 3y" +3y' -y = e^x -x -16
Solve the DE.
I get
y=c1e^x + c2(xe^x) + c3(x^2e^x) + 1/6(x^3e^x) -13 +X
Does this look right you.
My yc was c1e^x + c2(xe^x) + c3(x^2e^x)
yp was Ax^3e^x + B +Cx
how did you find Yp? i just learned this stuff in diff.eq and i never did a practice problem yet. my Yc comes out the same as yours.
-bonk's lil bro
To find yp I used the anihalator method.
y??? ? 3y? + 3y? ? y = e^x + - x +16
L=D^3 -3D^2 + 3D -1
L=(D-1)^3
Auxiliary Equation: (m-1)^3 =0
m=1 (multiplicity 3)
yc= c1e^x + c2xe^x + c3x^2e^x
L1=(D-1)D^2
L1L(y) = (D-1)^4D^2(y)
Auxiliary Equation: (m-1)^4m^2 =0
m=1 (multiplicity 4)
m=0 (multiplicity 2)
y= c1ex + c2xe^x + c3x^2e^x + c4x^3e^x + c5 + c6x
yp = c4x^3e^x + c5 + c6x
comes from the y= part with the yc part removed.
Another why to get yp is this
If g(x) is in the form
e^(ax) then yp=Ae^(ax)
k (constant) yp=A
Ax+b then yp= Ax+B
So our g(x) was e^x -x -16
For the e^x part we have Yp=Ae^x
For the -x part we have Yp=Bx+C ( I used B and C instead of A because I already used A in the e^x part)
For the -16 we can say Yp=D
We combine them by adding the terms together to get
yp=Ae^x + Bx + C + D since C and D are both constants we can just combine them to get yp=Ae^x + Bx + E
Since we already have constant times e^x in our yc we must multiply that by x untill we no longer have it in our yc. So we multiply it by x^3 since both a costant times xe^x and x^2e^x is in our yc.
So your final Yp=Ax^3e^x+Bx+E
in my notes my instructor said that we should at most use x^2. is that just for second order differentials? we're using 3rd order differential equation, so we can use x^3?
I dont know my book and teacher make no mention of x^2 being the most you should use. You dont want a value in yp to also be in yc though.
k (constant) yp=A
Ax+b then yp= Ax+B
wouldnt Yp = Ax^3e^x + Bx^4 + Ex^3 ??
since you're multiplying x^3 into the equation
edit-
ohh you should break up Yp into several equations so u can use the summation of Yp... right?
how did u solve for the coefficients
are you supposed to plug in Yp, Yp', Yp'', Yp''' into the original equation? im looking at the example from my notes, and this is how he solves for the coefficients
